SPECS CLUTCHES..?
06-27-2005, 06:03 PM
I ♥ Acer
SPECS CLUTCHES..?
i called to day to see what they carried..for my h/p level ..they got a clutch good for 550 hp and 610 lbs tq. at flywheel...is that better than a center force dual friction..?i got somewhere between 650 /750 rwhp 800 ft lbs tq.
06-27-2005, 06:21 PM
I ♥ Acer
RE: SPECS CLUTCHES..?
they can build a clutch that can take what you can give it
06-27-2005, 06:46 PM
Pro. B.S. caller outer
I have had good luck with them.
06-27-2005, 08:05 PM
i also have a spec clutch in my car and my buddy has one in his 2.2 KB cobra making 600 horse and he hasnt had any problems either
06-27-2005, 09:17 PM
I ♥ Acer
the one with the solid hub ..?
06-27-2005, 09:32 PM
solid axle? no it still has a stock irs
06-27-2005, 10:06 PM
I ♥ Acer
06-27-2005, 10:12 PM
I ♥ Acer
one of your problems is you need a quick ramp quadrant
06-27-2005, 10:33 PM
I ♥ Acer
Quote:
ORIGINAL: vfast
i got an alum one...plastic crap been gone...its the stage 5 or ..there mini dual disc set up ..with new flywheel....or go C-4 or PG.
06-27-2005, 10:35 PM
I ♥ Acer
pg with net very consist times
