Sponsored by:
Sponsored by: DashLynx
2002 ticks at startup
Old 06-29-2005, 05:10 PM
RedBaron233
RedBaron233's Avatar
Default 2002 ticks at startup
I am new hear and i did a search for my problem all ready and have not had luck. When i first start up car my engine ticks, as soon as it warms up it goes away. I have an 02 v6. i dont know whether or not it is an injector or a lifter. the ticking is LOUD. anyone know what this is about?
RedBaron233 is offline
Old 06-29-2005, 06:58 PM
PipsBlackStang
PipsBlackStang's Avatar
Default RE: 2002 ticks at startup
Ticking is usually linked to lifters, but a 2002 needing new ones???
PipsBlackStang is offline
Old 06-30-2005, 12:50 AM
white_snake
white_snake's Avatar
my cobra is loud as soon as i start it, but as soon as the oil flows it shuts up.
does yours do it until it gets warm or just for 5 seconds or so?, i know you said warmed up, but just checking.
how many miles on it?
white_snake is offline
Old 06-30-2005, 01:32 AM
02StanGT
02StanGT's Avatar
The two painful times my gt had a ticking or chattering noise, it ended up real bad. First it ended up being a timing chain tensioner that had failed (1200 miles from home). I had to get new heads. The second I thought was a lifter, but upon further investigation it was a rod knocking. I am not saying that is what it is, but just warning you that MAY be what it is. Hope its nothing serious.
02StanGT is offline
Old 06-30-2005, 03:10 AM
UhadMEatGT
UhadMEatGT's Avatar
Probably a lifter. I would have it checked for sure. Usually an injector is going to show other signs like running like poo. Plus its not going to go away when warmed up.
UhadMEatGT is offline
Old 06-30-2005, 04:11 AM
RedBaron233
The car has 68000 miles on it, I bought it with 50 and it ticked. It will tick for a minute or so, I am not car stupid which is why this is pissing me off do you think it could be the oil pump? i run 5-20 fully synthetic oil. i change it every 4000 miles, my problem might be that whoever had it before me switched to regular oil and screwed things up for me. I dunno. I hate to bring it to ford but i guess thats my only option, i just put a superchip in my car about 3 weeks ago and friday was going to be my first time running the car on a strip, what do u guys think... run it, or wait til it is checked out..
Old 06-30-2005, 08:11 AM
UhadMEatGT
UhadMEatGT's Avatar
Switching from regular oil to synthetic would not screw your car up and is nothing buy a myth.
Old 06-30-2005, 08:49 AM
Djs94stang
Djs94stang's Avatar
It does sound like a lifter. I'm not a big fan of the water thin 5w-20 that is recommended by Ford and Honda on some of their new engines. It isn't going to fix the problem but using a heavier oil may help for a little while. Hydraulic lifters can get gummed up and start sticking from lack of properly scheduled oil changes. Take off the oil cap and see if you can tell if the engine looks dirtier than it should. If so, try running some sort of cleaner in it...some use Marvel Mystery Oil but there are other products. Success is likely limited though.
Djs94stang is offline
Old 06-30-2005, 05:29 PM
babygurl2000
I ♥ Acer
babygurl2000's Avatar
lifter sticking perhaps?
babygurl2000 is offline
Old 06-30-2005, 06:04 PM
P Zero
P Zero's Avatar
5 W 20 wtf!!!!! CHANGE YOUR OIL TO 10W30 ITLL GO AWAY
P Zero is offline
Quick Reply: 2002 ticks at startup
