Sponsored by:
Sponsored by: DashLynx
What is wrong with my hood latch? 2000 GT
Old 06-30-2009, 08:28 PM
rjd2
rjd2's Avatar
Default What is wrong with my hood latch? 2000 GT
I'm having problems with the latch for the hood. I think it needs adjusted, or maybe replaced? It seems to be too high, and allows a gap in the hood, and also causes excess movement/play, thus making it more shakey on the highway or over small bumps. Here are some pics, notice the difference in height of the hood, and difference in the lever when i push it down. It is a huge gap that can be moved up and down pretty easily, and the hood stops are not that helpful, i have tried them at all different heights. The hood also needs to be dropped higher than usual for the latch to grab a hold and keep the hood down. Not really sure, any ideas? Thanks
Regular Height
Being pushed down by one hand
How it normally sits.
Being pushed down..
rjd2 is offline
Old 06-30-2009, 08:30 PM
aode08
aode08's Avatar
loosen the 2 10mm bolts on the hinge there, lower the hinge slightly, try and play.
aode08 is offline
Old 06-30-2009, 10:47 PM
socalwrench
socalwrench's Avatar
Also, make sure the rubber stoppers on the sides of the radiator support are adjusted correctly as well (they should touch and put moderate pressure on the hood when it's closed, BUT NOT lift it up excessively).
socalwrench is offline
Dokilar
15
10-16-2015 08:13 PM
ChampInSD
10-02-2015 04:55 AM
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
Quick Reply: What is wrong with my hood latch? 2000 GT
