Starting car after few years of sitting...tips?
Hi all,
I have an 83 GT 5.0 that has been sitting for a couple years. Just wondering any tips you might have to get her goin again. I already figure on changing the oil and draining all the gas. Is there an easy way to clean the carb/injectors? I was planning on dropping a lot of oil into the cylinders and let it sit for a while before i cranked it over. Then change to new plugs. Any tips, please let me know.
Thanks,
Ryan
Thanks,
Ryan
RE: Starting car after few years of sitting...tips?
your probably going to want to check the plug wires and distributor just to make sure that nothings rotted....also make sure that no little animals have made homes in your engine
Yea good idea to dump some oil into the cylinders first. I would recommend too the first time you turn the engine over with the sparkplugs out so to let the oil coat the cylinder walls & not just goo up the plugs.
Check your brake fluid and your rotors/drums, they're probably got a nice rust layer on them.
And get fresh gas into it ASAP. Siphon out whatever is in the tank now and put in fresh stuff, along with some injector cleaner.
ORIGINAL: GreyStang
Awesome thanks for the tips guys. Also just wondering if it would be worth pulling the carb and trying to figure out how to clean it, wouldnt it get a sludgy in there, like my 2-stroke dirt bike? I dont know very much about car carbs, they might be different.
Thanks again,
Ryan
Thanks again,
Ryan
ORIGINAL: 99saleen351r
I dont think your gonna find injecters on a 83 gt.
Yeah Ryan if you're gonna start using this car as a daily driver then going through the carb etc needs to be done. How well was it stored in the first place?
Ive had the car for about 8yrs now, and its been a project ever since, just about every part on its been replaced, its been sitting for a about 3yrs now and i do remember putting some fuel stabalizer in it before she went away, but thats about it. I dont think its been sitting long enough to seize itself, but i guess we'll find out on fri/sat when i plan on reviving her. As for her becoming a daily driver, i cant see it anymore this year, but id like to have her in tip top shape for next spring.
Thanks All,
Ryan
Thanks All,
Ryan
That american hotrod crazyhorse stang was totally set-up. A car that has sat in a barn for that long will never start right up. When they showed it on the truck the rotors were nice and shiney. A car that had sat that long would not have shiney rotors.
