Sponsored by:
Sponsored by: DashLynx
cutting lower springs
Old 10-14-2010, 07:10 PM
91smokedgt
91smokedgt's Avatar
Default cutting lower springs
Ok so i bought the HR sport springs and not the SS. After the install I set the vehicle down to find the front not as low as expected. the drop was 1.6 1.5. my question is has any one ever cut new springs????? Tire rack where i bought them from was no help.
91smokedgt is offline
Old 10-14-2010, 08:07 PM
LilRoush
LilRoush's Avatar
Let them settle a bit.... drive around for a week, see what you think then.
LilRoush is offline
Old 10-15-2010, 07:55 AM
91smokedgt
91smokedgt's Avatar
ok ill try that and see what happens.
Old 10-16-2010, 12:41 PM
Jfsram
Jfsram's Avatar
Isolators are worth about a 1/4"
Jfsram is offline
Old 10-21-2010, 04:27 PM
91smokedgt
91smokedgt's Avatar
ive never ran anything without isolators. will i have any noise?
91smokedgt
91smokedgt's Avatar
btw its been a week or so, still havent noticed any difference after letting everything settle
Old 10-21-2010, 08:44 PM
SilvrStang
SilvrStang's Avatar
It will take a week I agree. My eibachs were the same way it took a week to settle them in.
SilvrStang is offline
Old 10-24-2010, 01:00 AM
Drag5.0mustang
Drag5.0mustang's Avatar
Location: Parrish,Brandenton,Tampa,Florida,Gratiot Michigan
Cut em... 1/2 coil front ,3/4 coil rear.
Drag5.0mustang is offline
Old 10-27-2010, 09:15 AM
jsaleen90
jsaleen90's Avatar
Dont do it. you will completely destroy the ride quality not to mention have problems with alignment and wear your tire really fast. Springs are designed to have a specific spring rate. If you cut them this get all out of wack. If you have ever riden in a car with cut springs you wouldn't evev think of this.
jsaleen90 is offline
Old 10-27-2010, 12:11 PM
medrick
medrick's Avatar
did you make sure the bottom end of the spring was in the correct spot? if it is not sitting in the lowest part of the perch it will not sit a slow as it is supposed to.
medrick is offline
Quick Reply: cutting lower springs
