Sponsored by:
Sponsored by: DashLynx
sn95 rear brakes not working
Old 10-27-2011, 10:09 PM
ramair351
ramair351's Avatar
Default sn95 rear brakes not working
i have a 2000 v6 mustang, and my freind has a 97 v6 mustang. both of us have the same problem. the rear brakes do not stop the rear wheels. the pads are contacting the rotors, but with not much pressure. no brake lights or abs lights on. any ideas?
ramair351 is offline
Old 10-29-2011, 08:05 PM
LilRoush
LilRoush's Avatar
How did you check to make sure they weren't stopping the wheels?
Could be something as simple as air in the line.
LilRoush is offline
Old 11-02-2011, 11:28 PM
petrock
petrock's Avatar
Or seized up slider pins (very common).
petrock is offline
Old 11-03-2011, 08:21 PM
Chromeshadow
Chromeshadow's Avatar
Have you tried to bleed them? If the brake pedal feels normal, and you open the bleeder valve, the brake pedal should go all the way to the floor. Make sure you do not release the brake when the bleeder valve is open. btw, this is easy with two people, one pushes the brake pedal the other opens and closes the valve
Chromeshadow is offline
spectreman
03-31-2016 09:26 PM
JonnyBlazeGT
11-03-2015 01:10 AM
Tyoung68
08-25-2015 04:31 AM
Fast-Hands
08-19-2015 06:54 AM
cvarner131
08-17-2015 07:38 AM
Quick Reply: sn95 rear brakes not working
