03 GT Stumbling issue
Hey guys, New to the forum. I have a 03 completely stock GT. I bought this car back in March and its always had a stumbling issue. Mainly like backing out of a drive it will have an erratic idle and shut off. I also feel it surging while in overdrive with very little fuel demand. {Automatic Trans}I have replaced the TPS and the MAF sensor and no change. Id love some new ideas.... Thanks for the help
I think your two problems are unrelated. But the idle problem sounds like a bad IAC Valve (Idle Air Control Valve). Get a can of carburetor or fuel injector cleaner, remove the IAC Valve (should be on the air intake somewhere) and give it a good cleaning, let it dry for a couple hours and re-install. If that doesn't work, then it may need to be replaced. Not that expensive and most auto parts stores should carry it. Good luck...
Ive already swapped the IAC and still does the same thing. My father in law took a look at it the other night and I couldnt get it to do it outside of the car. I got it in it and put my foot on the brake and got it to do it. Now I am wondering if I have some kind of vacuum issue.....
When you changed the IAC, did you also clean out the air passages in the throttle body that the IAC valve controls? If they are clogged up, you'll get weird behavior too. However, a vacuum leak, down stream of the IAC valve, can also cause this problem. Good luck...
