Sponsored by:
Sponsored by: DashLynx
only 96xxx miles and i have a clicking noise
Old 03-03-2014, 03:47 AM
QuickWinZ
QuickWinZ's Avatar
Default only 96xxx miles and i have a clicking noise
Every Time I press the gas a rattling noise clicking noise is made
please reply and help im only 16 with no dad so i have no advice..
thanks
QuickWinZ is offline
Old 03-03-2014, 04:36 AM
SXGT
SXGT's Avatar
when driving or in park or both.
can you tell if the noise is under the hood, or under the car (exhaust)
SXGT is offline
Old 03-03-2014, 11:33 PM
QuickWinZ
QuickWinZ's Avatar
under the hood
Old 03-03-2014, 11:34 PM
QuickWinZ
QuickWinZ's Avatar
and when pressing the gas while driving
Old 03-04-2014, 07:28 AM
88 orangepeel notch
88 orangepeel notch's Avatar
I'm using the smart phone ap for this forum so I can't see your information. What year Mustang and engine do you have.
And to clarify, it's only while driving? While parked in neutral and you rev the engine……no tick/rattle.
Does the speed of the noise increase with engine rpm? Or speed of the car?
Does it sound like someone is tapping a screwdriver against your motor? Or is it more like someone is using a big hammer?
Does it get louder when the car warms up ?
88 orangepeel notch is offline
Old 03-04-2014, 04:06 PM
QuickWinZ
QuickWinZ's Avatar
1997 and v6 3.7 L
and only when pressing the gas while driving
no but the speed of the car it speeds up the ticks faster
and when it warms and its like a screw driver
thanks
Old 03-05-2014, 07:50 AM
88 orangepeel notch
Well, these are kinda hard to diagnose thru a forum. Trying to describe a sound, rattle or tick with words and have someone understand is tricky. But if the speed of the tick increases with the speed of the car and not engine rpm, that's a good thing as it's not in the motor. It's somewhere in the driveline after the motor, u joints maybe, or a stone or nail in one of the front tires. Hard to say without being there.
Old 03-05-2014, 08:06 AM
Chromeshadow
Chromeshadow's Avatar
Manual or Auto Transmission? There are a few other things you can do to narrow it down, does the tick get faster as you speed up, does it matter which gear you are in? Engine noises will change a little when the car shifts. It's a little more noticeable in a manual trans. If the sound is totally speed related, you might want to jack it up and check for looseness in the drive shaft U-Joints. These are easy to fix, and pretty easy to tell if they are bad. (by the time you can hear them-you'll be able to see them wiggle when you turn them by hand). I would also check all of the tires like orangepeel suggests.
Btw, never get under a car that is on a jack. Always use proper jack stands. Never use concrete blocks.
Chromeshadow is offline
Old 03-05-2014, 06:11 PM
QuickWinZ
QuickWinZ's Avatar
okay and so i took it in and they said it was somthing above the pistons some rings or something but i have to wait for a pay check
Old 03-06-2014, 07:10 AM
88 orangepeel notch
Whoa, could you tell is exactly what the mechanic said? Just so you don't get ripped off. We'll let you know if his diagnosis is even possible. Because there are no rings above the piston. Did he say anything about "lifters"?
Quick Reply: only 96xxx miles and i have a clicking noise
