Sponsored by:
Sponsored by: DashLynx
Who knows what this is ???
Old 04-24-2015, 01:37 AM
CyprusMustang
CyprusMustang's Avatar
Default Who knows what this is ???
When i purchased my car 8 years ago this was on the old intake manifold. Since then I've rebuild engine and changed lots of parts. However today while looking through my old parts I noticed this on the back of the manifold. Any ideas ??
CyprusMustang is offline
Old 04-24-2015, 04:58 AM
CyprusMustang
36 views no takers?? Come on guys...
Old 04-24-2015, 06:26 AM
jwog666
jwog666's Avatar
its a vacuum valve thats controlled by coolant temp, for a choke pull off maybe
jwog666 is offline
Old 04-24-2015, 07:11 AM
CyprusMustang
Whats the point of it?
Why would someone want it/need it?
Would this have anything to do with Vaccum needle bouncing back and forth?
Old 04-24-2015, 07:38 AM
88 orangepeel notch
88 orangepeel notch's Avatar
I don't think you need it with the air filter your running now. That vacuum switch would open or close the valve in the original air filter assembly intake neck, kinda acting like a choke so the engine would grab air from the hot exhaust manifold piping on a cold start.
But judging by your location, let me know if I should explain what "cold" is lol.
As for the bouncing needle, if all vacuum connections, and hoses are good, and there's no vacuum leak, some will say you may have a bad cylinder or some other internal damage.
From your other head gasket thread, has this motor ever been hydro-locked ? Doesn't take much to bend a connecting rod that way.
88 orangepeel notch is offline
Old 04-24-2015, 12:22 PM
CyprusMustang
If I had a bad valve, it wouldn't seat properly. All valves checked out ok at the machine shop. Not sure what else it could be??
Yea I know cold. I'm from NY don't forget /)
Old 04-24-2015, 12:33 PM
CyprusMustang
That think was in the water passage though. It has some sort of temp valve on it ??
Old 04-24-2015, 02:30 PM
WJBertrand
WJBertrand's Avatar
I think those valves were used to move a baffle in the air box so that when the engine is cold, warm air routed over the exhaust manifold is drawn from below to assist in fuel atomization in the carburetor and intake manifold. Improves cold starting performance and reduces emissions. Once the engine warms up, the vacuum valve moves the baffle to draw cooler air from the air cleaner snorkel instead.
WJBertrand is offline
Old 04-27-2015, 11:20 AM
88 orangepeel notch
Oh crap, I was just going by your "Cyprus", and after Googling it , thought you were some rich guy living in a Mediterranean Island paradise. The pic has that kinda feel to it lol.
