Xentec Bulb replacement And what color
I order a HI/LO kit a while ago and have no idea what temperature I bought. When I pulled out the kit and replace single beam kit I saw that one bulb was a little foggy. After install the foggy light never lit. I know I ordered blue but not sure exact temp order. The tag just says HI/LO BL. also Im not sure about the order by color of the four wires that control hi beam and low beams. I need to know where I can get replacement bulbs, how to determine right temp aka color, color sequence of wiring harness for hi/lo beam switch that plugs into oem harness!?!
blue is a bad color for headlights; it doesn't help you see better at night and irritates the **** out of other drivers.
http://www.danielsternlighting.com/t...e/bad/bad.html
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
