Hello ive got a 4.0 mustang & the car just stop accelerating on the road like the car was like coughing. Then the car dies out every time i touch the gas pedal or if it sits & idel for a little bit. i aslo had a fuse burnt out also. Now the car is complete dead & not starting at all. Im not no mechanic here just an 18 year old trying to get to work. I know the battery is dead but bad fuel pump? Please help thank you.
i replaced the burnt fuse. Replaced the fuel filter & fuel pump but the car still starts up rough & idles very odd. & as soon as i hit the gas pedal the car dies. Thank you for your help.
in safe mode the rpm only goes up to around 4k rpm. The transmission will shift early. Are there any Trouble codes?
the code is a very small leak an evap leak. Ive got no smoke machine to find the leak. It just seems like the motor aint getting fuel to it.
& another thing i didnt do with the fuel pump was realse all the preasure & use a compression tool.
the car doesnt idle that high goes to 1 to 2 rpm & bogs down.
Evap wont cause driveability issues. Sound like u might have a plugged up exhaust. Press the fuel pump reset button. its on the driver side left foot wall.
