Expensive oil change!
I got a flyer in the mail from the local Ford dealer for an oil change for 35.95. looked like a good deal so I went over and got in line for my oil change. While I was waiting in the lounge, the service writer came in and said I needed an alignment and it would cost 119.95, I needed my brake fluid flushed which would cost me 119.95 and I needed my injectors cleaned which would cost me 49.95. I own a 2014 Mustang convertible V-6 with a little over 40,000 miles on it. I was flabbergasted but politely told them thanks but no thanks, but go ahead and change the oil for now. I wonder how many people fall for this sort of scam and get this kind of work done at inflated prices. I had high hopes that I had found an honest dealer but I guess they are all cut from the same fabric. An hour later I paid them 42 and change (35.99 +tax) and left.
Bob in Bowling Green, Ky
Thats how mechanics make money. Yes those prices seem a little high but they are recommended services from Ford. The injection cleaning stuff is a lot a b/s but the brake fluid is recommended to be changed every 3 years. As for the alignment, do that when you get new tires or have tracking or tire wear issues.
To be fair, it depends on the condition of each item. 40,000 miles is more than most 2014 owners have managed to rack up yet.
If the tires are fairly new, it would be wise to have them aligned properly. But if they're due to be replaced soon, I'd hold off on an alignment until new ones are installed. Brake fluid? That depends on its condition too. If the car has been tracked, or has seen otherwise severe use, it very well might be time to change it.
At any rate, I find it odd that they suggested an alignment. Did they put it on an alignment rack to change the oil? I mean, you can't eyeball that sort of thing to see if it's out of spec (unless it's REALLY bad). It sounds like either the alignment is needed ASAP, or this is indeed a shady upsell.
I never said his car needed it now did I. I stated that those services are recommended at certain times. Do the math. 3 years on brake fluid, needs to be done in 2017. Guess what its not 2017 is it. The others dont have time limits but other determining factors that I listed in the first post.
Injector cleaning sounds like its just something to make money on. If your car was old and had mileage in six figures thats different..
Years ago I was at a dealer for an oil change and they told me my battery terminals were bad and they could replace for 45 bucks....I've never heard or seen that before. I passed and the vehicle was just fine afterwards.
Last edited by 99GTvert; 02-04-2016 at 02:18 PM. Reason: pissing out the window and ****ting out the windowa are two, different things!
I had a similar experience a couple of weeks ago. I was going to take the wife up to Sedona, (about a 2.5 hr trip from Phoenix with some pretty extreme elevation changes) for the weekend, and wanted to change the oil before the trip. I went to the dealership for an oil change the day before, and after they started the oil change, the tech comes out and says my power steering fluid was black and needed to be flushed, my fuel filter needed to be changed, and my drain plug was worn and needed to be changed. I left the dealership 2 + hours later, and the oil change I went in for cost me over $200.00.
