Go Back   MustangForums.com > Ford Mustang Tech > General Tech
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 06-05-2006, 08:02 PM   #101
Allan_York
Vehicle: 2001 Mustang
Default RE: GEARS
really? well that kinda sucks lol
what size rear end? 6.75?
__________________
1984 3.8 litre auto.
soon to have an 85 5.0
Allan_York is offline   Reply With Quote
Old 06-06-2006, 12:22 AM   #102
03YellowPony
Default RE: GEARS
Nope. Still 7.5. Now just think what it would feel like with 4.10 gears...
__________________
Sound clip http://h1.ripway.com/03YellowPony/S4300181.WAV
Sally's gone..
the REAL RedAss
MFFDTC #7
MFI#6
03YellowPony is offline   Reply With Quote
Old 06-07-2006, 07:03 PM   #103
Allan_York
Default RE: GEARS
hmm....interesting.....only problem is i have a 3.8 litre and it only made 120 hp, and thats when it was new. i would imagine im not making 120 hp now seeing how the car is 22 years old
__________________
Old 06-08-2006, 02:29 AM   #104
nsahoo
Default RE: GEARS
Ok, so i found out from mustangspecs site that these are my gear ratios
V6 Model GT Model
1st 3.35:1 3.37:1
2nd 1.99:1 1.99:1
3rd 1.33:1 1.33:1
4th 1.00:1 1.00:1
5th 0.68:1 0.67:1
Final Drive 3.15:1 3.22:1
So, what does that mean? when you say gear ratio of 4.1 .. do you mean the first gear has 4.1 engine rotation to 1 wheel rotation ratio? or which gear is it ?
Also, I have an automatic transmission with 4 speed gear. How does that work in that case. I know when I put it in drive the car changes gear from 1 to 3 or 4 as required. But, .. I am not sure if these gears are same as the ones I can choose my shifting the gear lever myself. Can some one clarify?
Thnaks a lot.
nsahoo is offline   Reply With Quote
Old 06-24-2006, 02:33 PM   #105
95hooptey
Default RE: GEARS
OK.....now I'm confused........I have a 95 GT auto asnd have been told I had 2.73s....I was about to get 3.73s to replace what do you guys think??? Do I need to got to 4.10 s? weekend driver car so I am not too concerned about gas mileage?
__________________
why are these yellow lights on?
95hooptey is offline   Reply With Quote
Old 06-25-2006, 02:24 PM   #106
CoBrAbRaT
Default RE: GEARS
i'll take a set of 3:73 for a 01 Cobra......with fries and a coke. lol
seriously......i want a set.
steve 403-561-9414
CoBrAbRaT is offline   Reply With Quote
Old 08-18-2006, 02:54 PM   #107
dothack
Default RE: GEARS
so if i wanna improve my 1st gear acceleration without killing my overdrive in my 96 GT auto..i should use 3.55 gears? i still have the stock ones so im looking to see which ones are good for a race or two during the weekend while keeping the car with good fuel economy for work on the week
__________________
my legend..
dothack is offline   Reply With Quote
Old 09-19-2006, 12:07 AM   #108
threeg502
Default RE: GEARS
I have the 3.73 gears in mine. You might be interested to know that I still get the epa 16/25
miles per gallon! First gear is really deep with 3.73s ! The car is an 86 efi GT
__________________
1986 GT EFI, 155lph pump, adj regulator, southside bars,koni shocks & struts, 3.73gears, bfgdrag radials, compucar 150hp shot of juice, no cats, flowmasters
threeg502 is offline   Reply With Quote
Old 09-23-2006, 12:44 PM   #109
Dagwood
Vehicle: 02 Ford Mustang GT
Send a message via AIM to Dagwood
Default RE: GEARS
Quote:
ORIGINAL: Buzzstang
MORE THAN LIKELY YOU HAVE AÂ*7.5 REAR END AND I WOULD RECOMEND THAT YOU CHANGE IT OUT FOR AN 8.8 REAR.Â* THE GEARS ARE PROUBALLY 2.73.Â* I WOULD GO BACK WITH SOME 3.55 BECAUSE YOU WULL NOT HAVE ANY OVERDRIVE UNLESS THIS IS JUST GOING TO BE A RACE CAR.
Easiest way if you have the cover off is to count the teeth on the ring and pinion then divide the ring number by the pinion.
__________________
Dagwood is offline   Reply With Quote
Old 10-02-2006, 04:13 PM   #110
lemonademaker
Default RE: GEARS
is it easier to swap out the ring/pinion and all the bearings, bushing and the necessary stuff OR the whole rear end ???
__________________
Gentlemen, start your engines!
Your car is as fast as your wallet is fat! - Me
lemonademaker is offline   Reply With Quote
14, 200509, 247, 28spline, 355, 373, 75, 88, affect, axle, ford, gear, gears, mile, mustang, rear, times
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
