s197 suspension
RE: s197 suspension
i haven't driven a gt mustang yet so i can't say much, so with the performance mods that im getting, cai, tune, exhaust, and gears im getting the impression that the stock suspension won't be able to do a good job handling on those mods? thanks for the replies!
RE: s197 suspension
ORIGINAL: Orion_240
well, how many cars out there are still Live Axle?
RE: s197 suspension
Modding your suspension really isn't a requirement because of increased power from a couple bolt-ons. My car has nothing but a K&N cai, canned SCT 91 octane tune, and Flowmaster AT axleback - that's it.
I do however, walk all over other Mustangs with as much as 40-50 horsepower more than me.
Like Al said - for most guys it's a matter of stiffening things up a bit and getting rid of some understeer. For the majority that means good control arms outback and a rear bar.
RE: s197 suspension
ORIGINAL: Iwasaricer
RE: s197 suspension
ORIGINAL: CrazyAl
#1: Rear lower control arms.
#2: Stiffer rear sway bar
#3: Stiffer panhard bar & panhard bar brace
ORIGINAL: hotairgypsy
so if you were to pick the order in which you want to replace parts for the suspension what would it be? at what point in the modding of the suspension are you sacrificing your ride?
I'm a bit hesitant to lower the car anyway, as roads in DC really suck.
RE: s197 suspension
RodeoFlyer makes a very good point. A lot of guys drop a lot of money into power mods such as tuners, pullies, gears, and that sort of thing but never spend a dime on suspension. These cars will spin the tires STOCK. Why add more power at the wheels if you can't use what you've already got? Spinnin ain't winnin..as some people say.
As for the clearance issues, I belive 100% that the often-reported "clearance problems" with the larger driveshafts are the result of an improper installation. I have installed 4" driveshafts (Spyder/Powerhouse/etc.) on several cars that are lowered, including my own, and have NEVER had a clearance problem. My car, even with 4 adults in it and the 4" shaft has never had clearance issues. In my opinion the clearance problems are not the result of the driveshaft itself, but instead occurs due to the pinion angle being set wrong or due to an excessively flexy UCA bushing. With the pinion angle correct there is no contact even with a 4" shaft.
Jay, The lowering & D-specs are great mods. I didn't write them down in my "suggestion list" becasue I have no idea what you may be wanting to spend. If you are willing to spend that kind of money then they are excellent. But the driveshaft is a great mod as well! Just be sure you have adjustable LCAs for when you get the driveshaft so you can get the pinion angle correct.
