SLP Line Lock install
Installed the SLP Line Lock kit today . . . took a little longer than expected, but hey, we aren't mechanics . . . ha ha
Install went smoothly, pre-bent lines were very nice . . .
only tough part about the install was the mounting of the silonoid . . . there is no way to fit a drill in between the valve cover and the strut tower to drill strait in. . .
we ended up using a small 1970's style drill and drilled at an angle to get one screw through . . . that was enough to hold with the brake lines and all . . .
bleeding the brakes of course wasn't too bad. . . All turned out well . . . I def recommend this for doing burnouts at the track with sticky tires. . . i have Mickey's, so this was pretty necessary, 2cd gear burnouts and all . . . lol
RE: SLP Line Lock install
ORIGINAL: explict
Thats awesome. Looking into getting Line Loc also down the road.
Got some pics?
How much did the kit cost??
Got some pics?
Bought them off RPM outlet for bout 130 or so. . . lines pre bent, wiring, switch, all you need . . .
