Tight Turning Noise
Old 11-02-2007, 06:29 AM
davisda1
davisda1's Avatar
Default Tight Turning Noise
I am hearing a whining sound when I do very tight turns or tight circles.
Can't tell if it is the brakes or the drive train. It 's a high-mid to high range sound whining as the wheels turn.
Has anyone heard anything like this? Is it anything to worry about?
No mods yet, 06 GT Stock.
davisda1 is offline
Old 11-02-2007, 06:35 AM
Vcoat
Vcoat's Avatar
Default RE: Tight Turning Noise
Sounds like your clutch packs need to be replaced. I believe its covered by the dealer,
Vcoat is offline
Old 11-02-2007, 07:14 AM
acascianelli
acascianelli's Avatar
Power steering pump?
acascianelli is offline
Old 11-02-2007, 10:55 AM
davisda1
davisda1's Avatar
The noise is coming from the far side wheel of which I'm tunning into.
For example when turning tight to the left the right rear wheel area is making the noise but it is deceiving, not sure if it is not coming from rear end drive shaft area.
davisda1 is offline
Old 11-02-2007, 11:19 AM
CataclysmGT
CataclysmGT's Avatar
If its in the rear, I'd be guessing something to do with the clutch packs in your limited slip diff.
BTW, when turning, its not good to hold the wheel against the stop....hard on the power steering pump.
CataclysmGT is offline
Old 11-02-2007, 11:51 AM
thaztrain35
thaztrain35's Avatar
im pretty sure its the power steering..
thaztrain35 is offline
Old 11-02-2007, 12:46 PM
hammeron
hammeron's Avatar
it doesn't have to be a tight turn,
to hear the differential moan
hammeron is offline
Old 11-02-2007, 02:13 PM
PonyBred
PonyBred's Avatar
i'm hearing the same thing with mine. after about half a wheel turn i hear the moaning but only at lower speeds (could be at higher speeds too but i wouldn't be able to hear it over my exhaust). i thought it was coming from the front wheels but my buddy was tellin me he thought it was coming from the rear. i'm takin my car into the dealership to get it checked out. i'll let you know what they say
PonyBred is offline
Old 11-03-2007, 10:17 PM
AshTang
AshTang's Avatar
ORIGINAL: PonyBred
Yup, let us know what they say it is..... Same noise here. I am convinced it is from the diff. myself.
AshTang is offline
Old 11-03-2007, 11:05 PM
craezjo
craezjo's Avatar
ORIGINAL: PonyBred
i think theres a tsb out number 06-19-2.
craezjo is offline
Quick Reply: Tight Turning Noise
