Car in Running again P1111 Code. Bad fuel injector? What do you think?
Thank you for the quick emails back and forth. As you know I got a P1111 code. I took it to Ford and they did not want to work on it but told me it was an injector. All free of charge. I found one in stock at the supplier Cal State. I installed my self with a little instruction from the tech at dealer. I have the new injector and all is fine. But I wanted to double check the part number of the new injector I am using to be extra safe.[/align][/align]On the box it says:[/align]Ford Motorcraft[/align]One[/align]CM-5093[/align]4G7Z-9F593-AA[/align]FUEL INJECTOR[/align][/align]On the injector:[/align]00 280 158 060[/align]1-12-7-06-054618[/align]4G7V-B5A[/align]927 >PA6< Ford[/align][/align]Do any of you think WHIPPLE will warranty this injector? Will FORD?[/align]
RE: Car in Running again P1111 Code. Bad fuel injector? What do you think?
are you wanting to confirm, that the
injector you bought was a 39lb
injector?
also, i'm not sure about the warranty issue...
injector?
Whipple site says kit includes a 38lb injector. I can not find a 38lb. FORD does not look them up by the lbs. They do it by the car. So I ordered a fuel injector for a 2006 Ford GT. it does not say the lbs.
Car runs fine but ??? Want to be sure??
[/size]EXCLUSIVE FEATURES:[/size][/size][/color][/font]
[ul][*]Instant boost, zero lag time for incredible throttle response[*]Revolutionary W140ax Whipple twin-screw supercharger[*]Massive 5†thick aluminum intercooler for superior cooling[*]Oversized Fluidyne heat exchanger for increased cooling capacity[*]Ford GT 38lb/hr fuel injectors[*]0 degree Ford Racing spark plugs[*]Twin screw supercharger is the most efficient SC on the market[*]Exclusive TRUE cold air intake system with 9†S&B “True-flow†filter[*]Self contained oil system, no tapping oil pan[*]Industry leading 95mm mass air flow meter[*]Exclusive cold air intake system with 9†S&B “True Flow†filter[*]Ford Racing flash programmer for industry leading power, reliability and durability [*]Zero tuning required, all pre-set[*]Available non-intercooled and intercooled[*][font=tahoma][color=#ffffff][size=2]Available for manual and auto transmission equipped vehicles[/ul]
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
