Just finished my Spec II clutch install.
Old 01-14-2008, 02:17 PM
acstone7
acstone7's Avatar
Default RE: Just finished my Spec II clutch install.
I dont even want to fathom getting to those top tranny-engine bolts [sm=headbang.gif]Thanks for the info nine.
acstone7 is offline
Old 01-14-2008, 02:24 PM
Mustang3GT07
Mustang3GT07's Avatar
How much harder is it to push the cluth in vs. stock? I ask this because i want to upgrade my cluth but i use my car as a DD. I also live pretty much rite by the city of chicago so there is alot of traffic and i dont want my leg to go numb lol.
Mustang3GT07 is offline
Old 01-14-2008, 04:06 PM
blackS197
blackS197's Avatar
So how does the clutch feel? Going to order a performance clutch soon.
blackS197 is offline
Old 01-14-2008, 06:00 PM
06Saleen3V
06Saleen3V's Avatar
I had a stage III clutch put in about two months ago and yes, it is a little firmer...but not bad at all. I actually like it better because I feel more in control. It is not even as bad as my brothers stock 99 cobra clutch...
06Saleen3V is offline
Old 01-14-2008, 06:53 PM
acstone7
acstone7's Avatar
ORIGINAL: 06Saleen3V
I need to upgrade, at the moment, i think i could powershift with mywang its so flimsy.
acstone7 is offline
Old 01-14-2008, 07:40 PM
Meangreen1200
Meangreen1200's Avatar
$300 bucks at the dealer. I did not even want to mess with it without a lift!
Meangreen1200 is offline
Old 01-14-2008, 08:10 PM
Diabolical!
Diabolical!'s Avatar
I'll try to address everyone's questions in one post:
First, driving impressions. The pedal effort is nearly identical to stock, but I am getting a very faint chatter at low RPMs. From what I understand this is common with Spec clutches because of the compound they use and will go away during the break in period.
The Spec II is rated for 520 ft. lbs.
Yes, I reused the stock flywheel. I had it resurfaced by a local shop for $25.
Bleeding the clutch is easier than bleeding your brakes. There is only one bleeder valve to deal with and you just make sure there is enough brake fluid in the resevoir.
I couldn't really get the motor tipped back any more without loosening the prothane motor mounts. I suppose it would be easier to tip the motor back some with the stock motor mounts.
Also, moose was right. The rear transmission crossmember cannot be removed with the H-pipe in. There are two hangers connected to it. Don't know how I missed that before...
Diabolical! is offline
Old 01-14-2008, 08:27 PM
airforceus
airforceus's Avatar
Good job nine....that must have been one helluva battle with no lift!
airforceus is offline
Old 01-14-2008, 08:55 PM
SirKnightTG
SirKnightTG's Avatar
ORIGINAL: acstone7
LOL!!
I don't think I'm ever going to ride with you.
SirKnightTG is offline
Old 01-14-2008, 09:04 PM
TASSY5
TASSY5's Avatar
Yo man, did you have the flywheel turned or replace it?
TASSY5 is offline
Quick Reply: Just finished my Spec II clutch install.
