Turbo or Supercharger & witch brand?
Old 04-23-2008, 11:31 AM
orangecrush
orangecrush's Avatar
Default Turbo or Supercharger & witch brand?
I have an 08 Gt/cs 5 spd, 4.10 gears. I am wanting to do a turbo or a supercharger witch is better on the motor. Also whats a good brand.
4.10 gears, SCT,Pypes axel back,Cold air, Pypes xpipe, throttle body spacer, & hurst shifter
car only has 1000 miles on it
EDIT: Removed ALL CAPS from thread title - 28HopUp
orangecrush is offline
Old 04-23-2008, 11:36 AM
howarmat
s197 Junkie
howarmat's Avatar
Default RE: TURBO OR SUPERCHARGER & WITCH BRAND
https://mustangforums.com/m_4902088/tm.htm
start here
howarmat is offline
Old 04-23-2008, 11:47 AM
blackS197
blackS197's Avatar
ORIGINAL: orangecrush
I think any kind of FI is awesome.
blackS197 is offline
Old 04-23-2008, 11:55 AM
orangecrush
I have looked at whipple & i have been told by shops down here you don't get the power. But I like what they offer in the H.O. kit.
Old 04-23-2008, 12:01 PM
moosestang
moosestang's Avatar
You get the 500+ crank hp they claim. 450rwhp is pretty standard for a whipple HO on a stock gt.
moosestang is offline
Old 04-23-2008, 12:06 PM
onederful100
onederful100's Avatar
so what kind of SC do they recommend if they say the whipple is so wimpy?
onederful100 is offline
Old 04-23-2008, 01:52 PM
zkiller
zkiller's Avatar
The two top choices for a blower would be a Kenne Bell or a Whimple. You can reach your performance goals easilly with either one of those twin-screws. Some of the Whimple buyers become gender confused after the installation and they join some alternative lifestyle thing they call the "Whimple Crew" but aside from that fact the supercharger itself is a very good kit.
Turbos are another story and I can not profess to know the better options for that choice.
Your shops down there are quite un-informed if they think they can not get the power from the Whimple. It is one of the best kits out there.
zkiller is offline
Old 04-23-2008, 04:02 PM
Androdz2
Androdz2's Avatar
Go turbo you will never regret it
Androdz2 is offline
Old 04-23-2008, 04:45 PM
sactown
sactown's Avatar
I went with the Saleen SC/475hp upgraded, IMO its the best and most effiecent SC on the market if you compare rwhp numbers, I am making as much HP as most the guys with Whimples and KB SC that are running 10psi of boost and I am only running 6.5psi.
With that being said if you ever plan on building a motor and running 20psi or more then you will need to go with something other than a Saleen SC currently they are only good for about 15psi, at least until the new Shacker hood setup comes out, but no one I know of has numbers on that yet.
sactown is offline
Old 04-23-2008, 04:52 PM
06Saleen3V
06Saleen3V's Avatar
If you want over 700rwhp, go turbo...if not, definitely do a twin-screw blower (Whipple, Saleen, KB)
06Saleen3V is offline
Quick Reply: Turbo or Supercharger & witch brand?
