Cam Phaser Limiters from Comp Cam
Old 07-28-2008, 07:04 PM
Brian_Zinchuk
Brian_Zinchuk's Avatar
Default Cam Phaser Limiters from Comp Cam
http://www.musclemustangfastfords.co...alve_cams.html
A lot of you might have already read this article about comp cams new phaser limiters. But I was wondering if people think its really nessesary to put these on if your running a stage 1 or 2 VSR cam. I've read this article a couple times now it it really seems that there not going to really do anything for the more mild cams and that they are really made for the aggresive cams like stage 3s comp cams for built engines.
Brian_Zinchuk is offline
Old 07-28-2008, 07:15 PM
Lt. Frank Bullitt
Lt. Frank Bullitt's Avatar
Default RE: Cam Phaser Limiters from Comp Cam
That is correct. NSR cams do not require them, besides, your bottom end torque and power will suffer if you do use them. Otherwise, for VSR and more aggressive grinds, yes, you want to use them as the risk of kissing a piston is greater. If comp cams indicates they are required in their spec sheet, then do it. If they say they are not required, believe it.
Lt. Frank Bullitt is offline
Old 07-28-2008, 07:35 PM
MyLocalDJ
MyLocalDJ's Avatar
I had the same question about my FRPP Hot Rod Cams that are NSR. I called Ford Racing and they said the same thing. No lockout or phase limiters were recommended.
MyLocalDJ is offline
Old 07-28-2008, 07:39 PM
Brian_Zinchuk
Well in the VSR cams that I'm getting it only states to change springs. Here is the cam that I'm getting installed, do I need the limiters? Even if I don't NEED them will it do any good putting them on?
http://www.compperformancegroupstore...y_Code=FRD3VCK
Old 07-28-2008, 07:44 PM
howarmat
s197 Junkie
howarmat's Avatar
If you do get the lockouts then why get the VSR cams and not the SPR???
howarmat is offline
Old 07-28-2008, 07:47 PM
Lt. Frank Bullitt
They will not hurt the midrange and up, but, they will hurt your low end torque and your wallet. Why buy something that has no benefit to what you are doing?
Old 07-28-2008, 07:50 PM
MexGT
MexGT's Avatar
ORIGINAL: Lt. Frank Bullitt
+1
ORIGINAL: Brian_Zinchuk
Those are the "old" stage 4 comp cams, and they dont require lockouts.
Someone correct me if i´m wrong but isnt 16.5* lobe separation angle a bit much for a SC aplication ?
MexGT is offline
Old 07-28-2008, 07:52 PM
Brian_Zinchuk
Ok thats the answer that i was looking for, they will be of no benifit at all.
howarmat: Cause I want to get some power and great sound from the cams, then I'm going up in boost after I get my aftercooler from Vortech. I dont need to be snapping rods on my dd.
Old 07-28-2008, 08:15 PM
Hootna
Hootna's Avatar
Just put in the 127300s got them from Brenspeed. They didnt send them in the kit and if they would be needed they would have said so. My car with the long tubes sounds great..
Hootna is offline
Old 07-28-2008, 09:28 PM
CataclysmGT
CataclysmGT's Avatar
I added Comp Cam Limiters in my engine build as a compromised safety net vs lockouts. I believe that they will reduce any VCT slap (if it occurs) to harmless levels, preventing phaser/cam pin failure. Someday in the future lingers new heads and cams anyway....so the $220 didn't really hurt right now.
CataclysmGT is offline
Quick Reply: Cam Phaser Limiters from Comp Cam
