tensioner and belt for whipple
Remember guys that your belt is going to slip a little because it has to. If your tension is to tight, you'd snap belts left and right.
Peter's (thumprr) tensioner is the ***** best IMO. I honestly would not worry about going to an 8 rib if I was under 450 rwhp, but that's just me. I'd just get the tensioner and a good gates belt.
If you're seeing a lot of belt dust, then chances are it's more of a rubbing/alignment issue than slipping. Check your belt to see if you are getting any fraying anywhere and then track the source. In some cases, one or 2 of Peter's billet 76mm smooth idlers are the easy fix as sometimes the belt likes to rub or hang on the edges of the stock idlers. The #7 pulley is also sometimes culprit (it's the ribbed one to the left of the power steering pulley).
You can go to gates website and enter your zip code and find local retailers for the belt...
http://www.gates.com/automotive/dist...ocation_id=539
thanks, i'll try just the tensioner w/ the idler, that makes me feel better since its cheaper than getting both.
and thanks for that link
Per Whipple: Gates only updates there retailers parts list once a year, so that is why they don't see it yet. I was able to get a couple of belts from a non major chain auto parts store. They didn't see that part number in their computer system, but they were able to get it from their Gates distributor.
Check your idler pullies, one of mine went bad and was causing my car to through belts. (pic included)
I just got my Thumprr tensioner today. I will be trying it out shortly. I purchased two billet idler pullies. They should be here tomorrow.
one 100mm and one 90mm
The 100mm pulley included in my HO kit was the one that went bad, but it doesn't make any sense to replace one and not the other.
stamped steel 100mm pulley - 11.2 ounces
stamped steel 90mm pulley - unknown
Billet 100mm pulley - 12.8 ounces
Billet 90mm pulley - 9.6 ounces
come to think of it, i've noticed the dust for a while now, but the squealing just started a few days ago. the belt looks fine, the ribs dont look shiny like they've been polished from the pulleys, but man i hate that sqealing noise, i've done some searches and i'm leaning toward this tensioner as the solution. i'm also considering an 8 rib conversion w/ the tensioner. i hate having the whipple in there but afraid to get on it bc i might strip the belt.
heres a link to the 8 rib
http://www.bggperformance.com/index....products_id=34
heres their tensioner
http://www.bggperformance.com/index....products_id=30
heres the thumper tensioner
http://shop.thump-rrrracing.com/prod...=1&productId=2
either tensioner is fine w/ me as long as it doesnt slip. anybody got any experience w/ either one, i here the thumprrr one is great, havent heard about the BGG one.
The 8 rib belt kit from BGG is the exact one I am getting and rocks! I know a few that have it and it works.
Is that a gash in the metal on your idler pulley?
My 100mm idler that comes with the whipple was making a sqeaking noise at low rpms. It eventually went away by itself.
Yes, it is. The metal is separated almost 3/4 of the way around. So the pulley would wobble badly as is spun.
