Steeda 90mm CAI/MAF and the Xcal or Pred tune
Ok, I just got off the phone with a rep from Steeda because I wanted to pick up their CAI. Well it appears that the new CAI is 90mm MAF not 83mm, and the Diab Pred does not carry a tune for it. The Xcal2 however does. As I was talking to the rep, he said that they should be coming in stock today, but he wasn’t able to tell me a whole lot about the differences between Xcal2 and Diab Pred. I got the impression from him that the Pred was better, however they will not have a tune for the 90mm Steeda for some time.
If I wanted to get the new CAI, I’d have to get the Xcal2 to tune it. I asked the guy if it did other things like change the rev limiter, remove the torque management, etc, but he didn’t think it did the same sort of things as the Diab Pred.
Can anyone give me some input on the Xcal2 and what it is good for, and if you can the new 90mm CAI from Steeda as well.
RE: Steeda 90mm CAI/MAF and the Xcal or Pred tune
I talked to one of the reps at Steeda and didn't come away with the same impression. I think the Xcal2 and the Predator are very similar, and should be fine with either as far as features and performance.
There's a bit in Mustang Monthly this month that says the SCT Xcal2's adjustable parameters include: global spark, fuel tables, idle rpm, WOT fuel, rev and speed limiters, gear ratio, MAF type, traction control disable, fuel injector size, transmission shift points and firmness, tire size, high speed data logging, and more. So that should cover you pretty well, just like the Predator.
hmm, maybe the guy you talked to was more knowledgeable then the guy I talked to. At any rate, I'm gonna get the Xcal2 and the Steeda CAI. I just like the Steeda name, plus they have a few other mods I'll get down the line.
09-17-2015 07:57 PM
09-16-2015 07:53 PM
09-10-2015 08:39 PM
09-08-2015 11:50 AM
09-01-2015 08:16 PM
