$1500 to spend, what combos will help my ET's the most
Old 07-31-2009, 06:34 PM
Icculus88
Icculus88's Avatar
Default $1500 to spend, what combos will help my ET's the most
So its nearing the end of the summer, out of the money ive made ive saved up $1500 to blow on my mustang. what is everyones suggestions?
o and i dont want LT's
my ideads were port job, vpr cams, maybe shorties but idk about installation costs
Icculus88 is offline
Old 07-31-2009, 06:39 PM
jahudso2
jahudso2's Avatar
nitrous will get you the best times for 1500
jahudso2 is offline
Old 07-31-2009, 07:46 PM
flounderlipps
flounderlipps's Avatar
Gears, spray and drag radials
flounderlipps is offline
Old 08-01-2009, 09:59 AM
Simon1
Simon1's Avatar
After looking at your list, I would get good tires and then cams. I don't think you have enough for both. Tires are the best mod for the track. Don't underestimate the gain you will get.
Simon1 is offline
Old 08-01-2009, 01:55 PM
kidnizmo
kidnizmo's Avatar
cams and shorties...done!
kidnizmo is offline
Old 08-01-2009, 04:52 PM
One Bad Stang
One Bad Stang's Avatar
i vote for Gears (4.10's) and drag radials. the gears should run you about $500 installed (parts and labor) and as for tires, brenspeed sells a mickey thompson e/t street wheels/tires package for $600 i think. then take the left over $ and go to lmperformance.com and get the j&m lca's and relo brackets and adjustable uca.
those mods will drastically reduce your e/t's at the track. the tires are the most important out of all of them in my opinion.
One Bad Stang is offline
Old 08-01-2009, 06:25 PM
white_lightning
white_lightning's Avatar
While an aluminum driveshaft is another idea its about $700 bucks but install is cheap. It would be nice because it will benefit you stoplight to stoplight, whereas wheels/tires will only be used at the strip. Savings will range from 1-2/10ths. I don't know what the gain from 3.55's to 4.10's is in the 1/4, but be mindful of the hwy mileage drop with that mod, which would only really be relevant if this car is your DD or you do a lot of driving.
white_lightning is offline
Old 08-01-2009, 07:32 PM
Stkjock
Retired Mod
Stkjock's Avatar
giggle gas
gears
drag radials
DS
Stkjock is offline
Old 08-02-2009, 01:16 PM
East87
East87's Avatar
Gears are a must (be a man and get 4.10's)
Spray is probably the most obvious answer in your case. At least get the gears, as it's a performance mod that you can use on the street or the strip to have fun.
East87 is offline
Old 08-02-2009, 01:25 PM
2007VistaBlueGT
2007VistaBlueGT's Avatar
If fuel mileage isn't a problem for you then gears and a set or drag radials will get you deep in the 12's.
2007VistaBlueGT is offline
Quick Reply: $1500 to spend, what combos will help my ET's the most
