The seas will boil and the dead shall rise...
By the way kiddies, don't try this at home...
To have a modular handle 8000 rpm it takes more than any of the head 'kits' from any of the vendors on here. No matter stage 1, 2, 3, 4, 100, etc, etc - all of the head packages for sale use the stock tappets/followers, the same manley exhaust valves, and one of the 1 or 2 standard spring choices and they are nowhere in the realm of being 'built' for high rpm spinning.
If you want to safely take your car into the 7400+ rpm range, you have got to get the right exhaust valves, a custom spring made for your set-up, and most importantly - you need to have JESEL in your car...period. Yep - expensive as sin, but Jesel is the only thing you want moving in your train. I have been through more motors than most and I think the train is the weakest link on 99% of the builds you read about on the internet.
If it doesn't look like this, it's not Jesel...
It is A LOT more horsepower than that...lol You have to understand - on a roller dyno, once we get around 800, it blows the tires off the rollers and we get out of it. Look at the dyno chart - it is at 800 at only 6300 rpm and the line is going straight up like a mountain. It will keep pulling and building power through 8000 rpm. I am going to be shifting at 7400 rpm.
I think it is at about 1100 rwhp right now if the dyno could hold it.
I believe in this very conservative tune up (only 10º of timing and 10.4 a/f) it is easily going to see mid 8's it's first time out at around 170 mph and I'll slowly turn her up. And I will be DRIVING her to the track...lol
By spring, I'm hoping to see a 7.9x @ 180 mph...
how in the world does the air get into the intake?? it has to enter in through the back, but why not the front?? on edit those dyno pulls shake even my computer
