Hit 170 today?
Old 07-31-2005, 05:40 AM
gregsdart
gregsdart's Avatar
Default RE: Hit 170 today?
I doubt that the 05 is limited to 150 due to drag, mainly due to having run almost 140 in a big boat of a 68 coronet back in 1970. That motor had only 280 to 300 net hp, about what the new 4.6 motor has, probably a tad less. Also, my coronet quit at that speed due to running out of gear, not power. It hit 5700 rpm, and that was a limiting factor due to valve float/hp loss due to the stock valve train.
So my guess is 160 + is very possible.
gregsdart is offline
Old 07-31-2005, 09:11 PM
v8stang05
v8stang05's Avatar
if you went 170mph that was good run, now im thinking of getting a tuner for my car.
v8stang05 is offline
Old 07-31-2005, 10:57 PM
LimeStang05
LimeStang05's Avatar
The drag limit numbers are on a car with factory HP. The more HP you make, the faster your 4.6 can push your car.
LimeStang05 is offline
Old 07-31-2005, 11:30 PM
KandyMan
KandyMan's Avatar
slow the hell down before you kill yourself or worse off...someone else......
KandyMan is offline
Old 07-31-2005, 11:42 PM
sk8erdudex
sk8erdudex's Avatar
Nice to see someone with some 05 and some *****
sk8erdudex is offline
Old 08-01-2005, 05:23 AM
JSP2005
JSP2005's Avatar
ORIGINAL: LimeStang05
Very true, however, a general rule of thumb is that for every 1% increase in top speed you need a 3% increase in power. So taking the factory power and drag limited top speed you'd need an extra ~ 105 HP to go 170.
JSP2005 is offline
Old 08-01-2005, 11:41 AM
ese
ese's Avatar
or you can use duct tape and some old cardboard boxes and make a more aerodynamic front end. I mean that will probably save you a few thousand in upgrades.....
ese is offline
Old 08-01-2005, 12:10 PM
AllVenom
AllVenom's Avatar
Ok, I'll be the first to do it, I call Bullsh!t. If you were going that fast with no real front splitter, you would have been squirrly as hell, in fact you probably would have lost control and killed yourself and someone to boot. There is a reason they put a speed rated governor on vehicles. It's for safety reasons. With the factory suspension and the front splitter and rear spoiler, it is safe at that speed. After that, your gambling.
I believe your calculations are incorrect because you did not take drag into effect, which someone mentioned. So, unless your pushing 400+hp, I don't think you hit 170.
AllVenom is offline
Old 08-01-2005, 12:39 PM
Daniel60
Daniel60's Avatar
O.K. I'll be the first to do it from the 2005 section, that is one Tough Cobra Dude! The other day when I was at the ford dealership getting my oil change, I read a mustang brochure and it was saying we have the guts of the cobra engine and Mach 1 can you intervein on that. Anyway if you can't I still think your car rocks.
[IMG]local://upfiles/11318/9B345C855AEE4CBAAA33CDC5A6D89ECA.jpg[/IMG]
Daniel60 is offline
Old 08-01-2005, 02:15 PM
sowaxeman
Retired Moderator
sowaxeman's Avatar
Since you are into mods - I think your next mod should be a 200mph speedo so you can set aside any doubt
sowaxeman is offline
Quick Reply: Hit 170 today?
