DTC P0430
Old 04-28-2010, 08:39 PM
F350-6
F350-6's Avatar
Default DTC P0430
05 GT with a stock engine and axle back exhaust. I've done a little reading here and the code seems common with a high flow kitty. Just got the car so I'm going off what the original owner said was done. I'm a little lost when poking around under the hood of this thing. Can anyone tell me where the rear O2 sensors are and how to test them just in case?
How would I tell stock vs. high flo cats by looking at them? I didn't really play around with the scanner to see what all I can monitor, but in case I can watch O2 data, what values should I be looking for?
I'm not scared of getting my hands dirty, I just don't understand enough about these engines to know what I'm doing, so please point me in the right direction.
The only other issue recently has been a dead battery in case that's related. Here's the data I've got so far in case it helps.
F350-6 is offline
Old 04-29-2010, 01:50 AM
Jersey Stang
Jersey Stang's Avatar
Yup, its very common among high flow cats. The rear o2's plug directly into the cat under the car. It should be a pretty thick green wire (iirc). And this upgrade is common with LT installs. So if you have longtube headers, then you probably have high flow cats. The best way to remedy this is to turn off your rear o2's. The rear o2's are just for monitoring and do not affect driveablity. If you email your tune to Brenspeed, they can adjust the tune for about $10.
Jersey Stang is offline
Old 04-29-2010, 05:35 AM
F350-6
F350-6's Avatar
Thanks. Problem is I just picked up the car. Headers are stock and I haven't crawled under there to look at the cats, but from talking to the previous owner, they are supposedly stock. Also, I have no tune to send off to get tweaked. (at least yet)
Just trying to figure out what causes this in a stock configuration.
F350-6 is offline
Old 04-29-2010, 07:31 AM
Jersey Stang
If its stock...usually running very rich will kill cats pretty quickly. how many miles are on the car? is it possible the cats are just going bad? the easiest and cheapest way to test it would be to switch the left and right rear o2 sensors and follow the problem. It usually takes me about 160 miles for the rear o2 to register a problem.
Old 04-29-2010, 01:18 PM
SpartaPerformance
SpartaPerformance's Avatar
I replied to your thread on Stangnet. I'm not typing it again. LOL
SpartaPerformance is offline
Old 04-29-2010, 02:22 PM
zkiller
zkiller's Avatar
running leaded racing fuel will kill your cats too.
Brenspeed cant adjust anybody's tune but the tuness that Brenspeed originally created. Tunes are locked by the original creator.
They also cant adjust your stock PCM configuration at all.
zkiller is offline
Old 04-29-2010, 03:10 PM
GT John
GT John's Avatar
Looking at your data:
The front o2 sensor for bank two needs to be replaced (Short Term Fuel Trim Bank Two - 10%) it is not reading as close to bank one as it should.
The front o2 sensors control the A/F when in closed loop. In WOT they are out of the picture.
The rear o2 sensors are there just to monitor the cats. They play no other part.
GT John is offline
Old 04-30-2010, 06:08 AM
F350-6
F350-6's Avatar
Mileage is around 43,000. If the weather cooperates I'll switch the right and left sensors this weekend.
Thanks. I thought that number looked out of place, but didn't know what the default values should be.
Is there any way to ohm out an O2 sensor to see if it's good, or should I just switch things around and see if the code comes back?
F350-6 is offline
Old 05-17-2010, 05:23 PM
Wildpig51
Wildpig51's Avatar
having a simular problem thanks for all the info.......
Wildpig51 is offline
Old 05-17-2010, 08:46 PM
F350-6
F350-6's Avatar
Haven't got the problem to show up again so it's still a work in progress. I'll update if it shows up again.
F350-6 is offline
Quick Reply: DTC P0430
