My new ride
#63
Pretty straight forward. Stallion Suspension has a youtube video of the install too.
http://www.youtube.com/watch?v=BBkvvJCrFRo
I'm still saving for that.
#66
Not sure if there is a major long-term effect, but under hard acceleration it will want to pull/slide to the side that's sticking out. So from a dig or hard 1st to 2nd shift it will slide out a little from under you to that side. I have one on mine and it helps control under hard accelerations. I didn't see what all you installed, but you'll want to have an upper control arm to adjust the rearend/pinion angle as well. LCA's will help with the keeping the wheels (wheel hop issue) on the ground and better weight transfer for better traction.
#67
#68
