How Much HP/TQ Can a 05-07 GT Transmission Handle?
Old 08-10-2012, 02:22 AM
C500GT
C500GT's Avatar
Default How Much HP/TQ Can a 05-07 GT Transmission Handle?
Just wondering what the braking point is plus whats a good amount of HP and TQ for the stock T-3650 manual transmission. Am guessing it can safely handle around 500 hp, not too sure has anyone figured it out?
C500GT is offline
Old 08-10-2012, 09:25 AM
outceltj
outceltj's Avatar
I've asked my tuner and he said once u get above 500 hp. It's gonna let go sometime.
outceltj is offline
Old 08-10-2012, 09:32 AM
moosestang
moosestang's Avatar
I think 550 crank is a pretty safe bet, not for the stock clutch though. Whipple obviously feels comfortable with that amount of power on the stock transmission. I'm more worried about the rods. Replacing a transmission is relatively cheap and easy in comparison.
moosestang is offline
Old 08-10-2012, 09:35 AM
TommyB681
TommyB681's Avatar
ive heard around 500 without having to swap for better parts.
TommyB681 is offline
Old 08-11-2012, 01:26 AM
C500GT
C500GT's Avatar
i thought as much thanks for the input guys much oblige.
C500GT is offline
Old 09-06-2012, 12:16 PM
TRexGAWD
TRexGAWD's Avatar
Depends on what you're going to be doing with the car.. A transmission can handle it easily if you're gently with and drive normally.. If your power shifting though don't expect it to last very long if you have a power adder.. Oh and the strength of a tranny is based on the torque the car is producing and not the power.. . Personally I would keep a stock clutch in their if you supercharge it, the clutch will go if before the transmission if you put too much torque on it. It's like a safety
TRexGAWD is offline
Old 09-06-2012, 08:11 PM
SpartaPerformance
SpartaPerformance's Avatar
550 bhp is safe provided you don't run drag radial. A full slick with a soft sidewall would be ok but the clutch at that point becomes the weakest link.
SpartaPerformance is offline
Old 09-07-2012, 03:40 PM
ZPounds07GT
ZPounds07GT's Avatar
Check this out, doesn't give HP rating but it gives torque. I'm not real sure if this will help but.. Here ya go anyway. Tremec Transmissions
ZPounds07GT is offline
Old 09-07-2012, 03:48 PM
Derf00
Gentleman's Relish
Derf00's Avatar
Didn't you post a link not to long ago for things that start to fail at higher HP for our cars? It was a link to a performance company that had extensive experience in Mustangs. They documented for instance that at 400hp in an auto, the solenoids may give and that at 425 wrist pins start to get strained in the stock motor....?
Derf00 is offline
Old 09-07-2012, 05:10 PM
moosestang
moosestang's Avatar
Did I? I remember that, but not sure I posted it.
Quick Reply: How Much HP/TQ Can a 05-07 GT Transmission Handle?
