15 inch drag slicks rim fitment
Old 11-02-2012, 08:59 PM
slickman
slickman's Avatar
Default 15 inch drag slicks rim fitment
will a 15x8.5 with a 5.5 BS fit a s197? If so, is there anything that needs to be modified. It looks like it would be close but not sure.
slickman is offline
Old 11-02-2012, 09:07 PM
Diabolical!
Diabolical!'s Avatar
Depending on the brand, that size will clear without having to relocate the rear sway. However, if you run a very wide and tall tire on that rim, it may rub the fender on hard launches. I have 2 sets of rear 15"s, one for street and one for strip. My street wheels are 15x10 with a 7.5" BS and required a rear sway bar relocation. My strip wheels are 15x8 with a 5.5" BS and did not require any modification. All of my wheels are racestars.
Diabolical! is offline
Old 11-02-2012, 09:36 PM
slickman
slickman's Avatar
What size tire are you running on the strip rims?
slickman is offline
Old 11-02-2012, 11:00 PM
Diabolical!
Hoosier QTP 27x11.5x15. They lay down a nice contact path and hook excellent. My street tires are 28x12x15. They are strictly for looks and hook like crap, lol.
Old 11-02-2012, 11:57 PM
slickman
slickman's Avatar
Well, this is what I'm looking at used. From what your telling me, they should be fine? Mickey Thompson ET Drag Slicks 28x10.5x15 on Jegs Sportstar Wheels 5 lug 5.5 BS
slickman is offline
Old 11-03-2012, 12:52 AM
Diabolical!
That combo should work, but the height and width of the tire will be cutting it close. Those rims would stick out 1/2" farther than mine, and mine are VERY close, but I also have a wider tire. I really think you'll be OK, but I'd test fit them to see if the tire clears and the rear brake caliper clears if possible. I'm not familiar with the jegs wheels, but some drag wheels need a small spacer on S197s to clear the caliper.
Old 11-03-2012, 12:58 AM
slickman
slickman's Avatar
So when guys are talking about wheels clearing the caliper, they are talking about the space between the inside face of the rim and the outside face of the caliper?
slickman is offline
Old 11-03-2012, 01:08 AM
slickman
slickman's Avatar
Correction, the wheels are 15x8 with a 5.5 BS
slickman is offline
Old 11-03-2012, 08:55 AM
slickman
slickman's Avatar
Well, I purchased them. Got the set (50% tread left) for $480 shipped. If they don't fit, I'll just resell them. Comes with Mickey Thompson ET Drag Slicks 28x10.5
slickman is offline
Old 11-03-2012, 12:36 PM
Diabolical!
That's the perfect size for these cars and should fit without any modification.
Quick Reply: 15 inch drag slicks rim fitment
