Arrrgh....dead battery rant....
Old 01-15-2013, 01:46 PM
tezz
tezz's Avatar
Default Arrrgh....dead battery rant....
Totally my fault - when I flipped the headlights off and ran in out of the cold, it only made it to the parking lights. No biggy... but the jumpers are in the trunk...and with a dead battery the electric trunk switch won't work and there's no longer a key lock - you have to crawl through the back seats to reach the emergency latch . And those 'trick' door windows that lower 1/2 an inch when you open the door? yeah, they don't work either...so when you pop the door open, you can't close it again.
Of course the battery was so dead my truck couldn't jump it. I couldn't leave with the door open so waiting for AAA was the only option.
I think I need to get the window re-timed now - it's not closing as it should.
(sigh)
tezz is offline
Old 01-15-2013, 02:44 PM
duckbubbles
duckbubbles's Avatar
The best learned lessons are the ones that really bite you.
Frank
duckbubbles is offline
Old 01-15-2013, 08:16 PM
JFitz
JFitz's Avatar
You can still close the doors. Just futz with the molding and bend it up a bit. It's a tight fit, but as long as you go slow, it won't break the glass.
Just don't slam it.
Learned that the hard way, just like the OP did.
JFitz is offline
Old 01-16-2013, 04:45 PM
Nuke
Nuke's Avatar
The window recalibration procedure should be in the OM like it is for the 05-10's.
Nuke is offline
Old 01-16-2013, 10:27 PM
808muscle
808muscle's Avatar
Oh the dominoes just kept getting knocked down. I can hear the frustration. Bummer dude. Some day you will laugh about this event. At least you have a new cool car.
808muscle is offline
Old 01-17-2013, 12:45 AM
Ricardo
Ricardo's Avatar
Carefully push lightly on the top of the window as you slowly shut the door, itll give you enough clearance to get past the moulding overhang and then let off the window as you push the door closed.
Ricardo is offline
Old 01-17-2013, 06:20 AM
tezz
tezz's Avatar
Thanks, Nuke - I'll dig for it.
It's not so askew it won't close now just enough for the noise to bug me.
tezz is offline
Old 01-19-2013, 10:18 AM
157dB
Cut & Paste Expert
157dB's Avatar
doors closed
windows down and hold switch for 3 seconds AFTER window bottoms out
run window up and hold switch up for 3 seconds AFTER fully closing
repeat 1 more time
window calibrated
A charging jack located behind the front fascia works for me.
Or a quick pull on the release cable jacket
at the hood latch will get the hood open from outside the vehicle
157dB is offline
Old 01-20-2013, 01:29 PM
tezz
tezz's Avatar
I found it in the manual - thanks.
Access to the battery was easy - just doesn't make sense to keep cables in the trunk with a power trunk lock. Or remember to keep them in the back of the trunk where access thru the back seat is easy. Something to remember.
tezz is offline
BOB ROME
07-26-2023 01:54 PM
4cylinderplus2
10-09-2020 07:45 PM
logan409
09-26-2015 07:43 PM
wilsonro
4 Cylinder NA and Turbo
09-11-2015 07:13 AM
Art161
09-09-2015 10:33 AM
Quick Reply: Arrrgh....dead battery rant....
