RPM Issues
Old 03-28-2013, 11:56 AM
sbradle4
sbradle4's Avatar
Default RPM Issues
Warning, this is going to be a long post...
Ok, so, my 2010 GT, with automatic transmission is having some RPM issues (still).
While STOCK:
When coasting, the RPMs will drop from 1500rpm to 1000rpm, then rise back to 1500rpm and then fall gradually. When coming to a complete stop, the rpms will surge from around 650rpm up to 1000rpm, and settle back to idle.
When Steeda Tune and CAI installed: When coasting, RPMs will bounce constantly up and down from 1000rpm to 1500rpm, until I get to a point slow enough that it will fall to 1000rpm. When coming to a complete stop, the RPMs will surge from around 650rpm to about 1200rpm, then settle to idle (you can feel the car lurch forward).
I have cleaned the throttle body, I have cleaned the MAF sensor, recleaned the air filter with LIGHT amount of recharge oil.
Took the car to a dealer returned to stock, and they tell me the rpm issue when coasting is because the torqued converter is disengaging, and this is "normal". When coming to a complete stop, he tells me the surge is "normal", that it is something that Ford has it programmed to do for fuel economy.
So, my questions are: Is this normal behavior for a stock mustang?
I had the issues also with Bama Tunes, thought it was the tune, but I get the same issue with the Steeda tunes. So what is wrong with my car? Any suggestions?
sbradle4 is offline
Old 03-29-2013, 09:26 AM
allenmaty
allenmaty's Avatar
That is a 4.6L right? I would suggest checking the idle control valve or replace it.
allenmaty is offline
Old 03-29-2013, 09:36 AM
kevinmalec
kevinmalec's Avatar
I've had this issue "off and on" since I've owned my car, stock and with custom tunes. Over the past year, I wasn't experiencing the high idle issues, then I recently replaced out my thermostat housing and the issue started back up. :-/
I have a manual, so it typically idles high when i slow down and shift into neutral.
kevinmalec is offline
Old 03-29-2013, 09:37 AM
AMDanBailer
Former Sponsor
AMDanBailer's Avatar
There's a few different things this could be. I would recommend checking/cleaning the Idle Control Valve, MAF and Throttle Body! Also, check for all vacuum leaks.
This is the first place I would look. Since it looks like you already have a Bama tune, if you'd like to you can give my Bama team a call and they'll walk you through this process and help you troubleshoot then get you a revised tune file sent out!
Let me know if you have any questions or need some assistance. I hope this helps! Our Bama Performance tuning specialists are here in the building Monday-Friday from 9AM-5:30PM EST and Saturday 9AM-5:30PM EST. You can hit them up directly at 888.226.9764 and they'll get you squared away!
-Dan
AMDanBailer is offline
Old 03-29-2013, 10:24 AM
sbradle4
sbradle4's Avatar
Dan, I HAD a bama tune had 3 different revisions, and didn't sort it out, so I went with Steeda. Now, same issues. The newer 4.6L have an "open flow" idle air control system, it goes from the valve cover on the driver side to the intake manifold behind the TB, and from the air intake hose just in front of the TB to the valve cover on the passenger side. It's not really something to be cleaned.
Also, PLEASE note I have already cleaned the TB and MAF, so that is not the issue.
sbradle4 is offline
Old 03-31-2013, 02:41 PM
sbradle4
sbradle4's Avatar
No one? Maybe my car is an anomaly... Sheesh.
sbradle4 is offline
Old 04-01-2013, 02:20 PM
kevinmalec
kevinmalec's Avatar
I also cleaned my TB, MAF sensor and CAI. It helped a little, however it didn't eliminate the high idling issue.
Old 04-01-2013, 10:42 PM
sbradle4
sbradle4's Avatar
Thanks Kevin. So you are just living with it I assume?
sbradle4 is offline
Old 04-02-2013, 11:14 AM
kevinmalec
kevinmalec's Avatar
Yeppers! It idles high off and on!
Old 04-02-2013, 03:21 PM
sbradle4
sbradle4's Avatar
Awesome (
sbradle4 is offline
Quick Reply: RPM Issues
