Cold engine bogging after CMDP's?
Old 05-06-2015, 12:05 PM
ghunt
ghunt's Avatar
Default Cold engine bogging after CMDP's?
Wondering if anyone else has experienced this.
Over the winter I removed my CMDP's (motor & all) and got a Bama tune through AM.
On a cold start in the morning, when temps outside are cooler, the engine bogs really bad below 1500-2000 RPM or so. Above that it's fine, and once you drive it a mile or so, it goes away. It also never does it when outside temperatures are warmer, I've never once noticed it when leaving work even when the car has sat 8+ hours while I was at work. Other than that the car runs great and I'm getting no CEL.
What's causing this, is it just the now wide-open ports and cold engine just being sluggish at startup?
ghunt is offline
Old 05-06-2015, 08:17 PM
jpplaw
jpplaw's Avatar
Sounds tune related, probably the MAF transfer. More air is getting into the cylinders and the cooler temps exacerbate it a little bit to the point where it bogs a hair lean.
jpplaw is offline
Old 05-07-2015, 05:08 AM
Dino Dino Bambino
Dino Dino Bambino's Avatar
What he said.
Dino Dino Bambino is offline
Old 05-07-2015, 11:39 AM
AMAlexLazarus
Former Sponsor
AMAlexLazarus's Avatar
Hey - Sorry to hear about the trouble here. It's sounding like this could be tune related as this is only occurring on cold start and it's likely in relation to a table that's associated with coolant temp. Please shoot the Bama Team a call and they'll work with you to have this sorted.
Alex
AMAlexLazarus is offline
Old 05-12-2015, 03:16 PM
ghunt
ghunt's Avatar
I will have to do that.
It seems like the temp threshold is around 70 degrees- the last couple days I have left for work and the the temp was above 70 in the morning, and it ran fine. Kinda weird.
ghunt is offline
Nick Oliver
10-17-2018 04:22 AM
Pyrate Dave
09-10-2015 07:30 PM
cbird1177711
09-02-2015 04:12 PM
Quick Reply: Cold engine bogging after CMDP's?
