Can i get some help with these door locks please?
Old 07-01-2016, 02:36 PM
chappie25
chappie25's Avatar
Default Can i get some help with these door locks please?
My driver side door wont unlock with the key for or either one of the door switchs. It will lock perfectly fine, but not unlock. the passenger door is fine. I bought a new actuator thinking that would be it but still the same issue. i have checked every fuse in the engine bay as well as the passenger panel. I put a meter on the 2 wire plug in the door and when i hit the lock button i get some voltage, when i hit the unlock button i dont get anything. I seen somewhere the the driver door switch is the white/purple wire in the black 26 connector in the passenger fuse box so i looked around in there and didnt see anything suspicious that would be causing the problem. F126 is the door unlock fuse in the engine bay, does it run through any other relays? Or where exactly is this keyfob remote initiate at? The wire in the door connector is a pink/orange and a white. Does anyone have a good wiring diagram so i can chase it back to its origin. Thanks.
chappie25 is offline
jgull1g
03-23-2016 01:49 PM
Lee1911
03-05-2016 05:34 PM
Lee1911
03-03-2016 08:05 PM
mattkm
05-26-2003 03:31 PM
spike306
05-01-2003 03:40 PM
Quick Reply: Can i get some help with these door locks please?
