Need your help guys
RE: Need your help guys
well, the emost common is the 4.10's /4.30's.
personally i would use the 4.10's, but if you want an even more grip and feel the 4.30's will make a pretty big diffrence.
Mach1 4R70W ratios as follows
2.84
1.55
1.00
0.70 (OD)
Manual
.62 ratio, 80mph, at X.XX:1 rear gear ratio
3.55 = 2304 rpm
3.73 = 2421 rpm
4.10 = 2661 rpm
4.30 = 2791 rpm
4.56 = 2960 rpm
top speed w/ 3.55s, 5th gear @ 6798 rpm = 236 mph
top speed w/ 3.73s, 5th gear @ 6780 rpm = 224 mph
top speed w/ 4.10s, 5th gear @ 6787 rpm = 204 mph
top speed w/ 4.30s, 5th gear @ 6769 rpm = 194 mph
top speed w/ 4.56s, 5th gear @ 6771 rpm = 183 mph
i dont either so, i'll be posting other peopls stuff.
from what i'm reading if it's a daily driver its a toss up, most are picking the 4.30's. there is only a 100rpm diffrence in between the 4.10's and 4.30's. and the 4.30's are adding a pretty good snap to them.
summit has them
2.84
1.55
1.00
0.70 (OD)
Manual
3.55 = 2304 rpm
3.73 = 2421 rpm
4.10 = 2661 rpm
4.30 = 2791 rpm
4.56 = 2960 rpm
summit has them
the normal driveshaft weighs like 14lbs i think, and the aluminum only weighs 7lbs. so the motor will have to do less work to turn the drive shaft leaving more HP and TQ available to go to the tires.
