Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
5w30 oil okay?
Old 04-16-2009, 05:51 PM
rygi23
rygi23's Avatar
Default 5w30 oil okay?
Dude at the shop I always take my car to had a brain fart and installed 5w30. They're really cool so I didn't get all upset and figured it'd be okay. Y'all think it's okay? Also, oil changes have gotten very expensive at shops when using full synthetic, even after coupons. Since I've lowered her it's impossible to get ramps under the chin. Anybody got any ideas to be able to get under the car. Thx!
rygi23 is offline
Old 04-16-2009, 06:16 PM
03MachMe
03MachMe's Avatar
yea 5-30 is fine lots of ppl use it from what i have heard the only reason they say to use 20 over 30 is because of emissions. and how i change the oil is i jack it up on one side and get under the car and do it myself
03MachMe is offline
Old 04-16-2009, 09:06 PM
Sace
Sace's Avatar
I cant get my jack under my car even from the side. Ive got a high point where the grass meets the driveway. I just pull it onto the grass then jack up the front a few more inches.
Sace is offline
Old 04-16-2009, 09:07 PM
denice25
denice25's Avatar
Its cool man...
denice25 is offline
Old 04-19-2009, 10:34 AM
LynnBob Mustang
LynnBob Mustang's Avatar
Drive up on 2 2X8 blocks of wood, one under each tire, that should get you up high enough to get a jack under the K member or a arm.
Lynn
LynnBob Mustang is offline
Old 04-22-2009, 12:36 AM
josh662234
josh662234's Avatar
http://www.mustangworld.com/ourpics/...amps/index.htm
Perfect set of ramps. and ya 5w30's fine
josh662234 is offline
Old 04-24-2009, 10:49 AM
cesar5571
cesar5571's Avatar
Check out Rhino Ramps. They are specifically for low cars and work great on my Mach 1.
cesar5571 is offline
Old 04-24-2009, 12:24 PM
HamMach1
HamMach1's Avatar
Not for lowered low cars I have those but I can't use them to lift up the front, only the rear.
But yeah it seems 5w30 is fine. A believe quite a few people over on M1R use it.
HamMach1 is offline
Old 04-26-2009, 08:47 PM
1HottMach
1HottMach's Avatar
Maryland huh! You'll be ok before the summer starts.. I run a heavier weight when it's hot out.. The 2 pieces of wood like someone else had mentioned is a really great way! I cut my wheel hard right and get a small jack under the a-arm and jack it just enuff to get the good jack under the member.. Aggghhhh the things we have to do to keep up appearances LOL
1HottMach is offline
Old 04-27-2009, 12:38 AM
03MachMe
03MachMe's Avatar
i think im going to have to do that! never thought of that but should work w/o a problem
03MachMe is offline
wraith777
09-28-2015 10:49 AM
Shadow7874
09-24-2015 09:06 PM
belam
Oil and Oil Related Topics
09-23-2015 11:29 PM
Demodulates
09-18-2015 11:14 AM
kevsgt
09-09-2015 06:20 AM
Quick Reply: 5w30 oil okay?
