finished install on intake spacer..guess what!!
ok, just finished the intake spacer and after following every step I still messed up the egr bolts. I think I cross threaded the rear bolt and there is a slight gap. The car stumbles and idles like it has a cam. There is also a hissing sound coming from the upper intake area. Im pretty sure its the egr. I called my builder and he is going to have a delete kit for me in the morning. I hope that is the problem, what do you guys think?
954 don't pay that ***** any mind even if his dumb arss writes back. Yeah man I'd say that gap should be the problem if you made no other changes. With your fitment issue, am I correct in assuming you got the 1/2" spacer? I'm running out of modestly priced bolt-ons to get, but I'm going 3/8" if I get one, I hear it's much easier to hook the EGR back up.
954 let us know if you do see any gains. I was thinking of doing this myself but there is alot of conflicting info. Gains vs. no gains? I would say the gap is your problem. You could try running a tap into the hole to try to straighten out the threads. Don't break off the tap whatever you do.
I am getting the delete kit tomorrow. I will see when I take out the bolt if I will have to retap the hole, I hope not!! The gains seem to widen the power band on both hp and tq, but mostly tq. The tq, while maybe only 6-10 ft pounds will come on sooner and stay longer! We will see tomorrow, thanks for the replies!
I also had trouble with the egr bolts when i installed the spacer. didnt cross thead em tho. i would say you prolly have a vacuum leak at the egr valve. have fun removing the egr tube from inbetween the head and firewall, I had to cut mine to get it out. Also I would suggest a hand-held tuner so you can turn the cel off when you unhook the egr system. And to answer the other posters question. No removing the egr does not add power.
