Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
Misfire in cyl #4
Old 12-06-2013, 05:41 PM
TXMach
TXMach's Avatar
Default Misfire in cyl #4
2003 Mach 1. K&N drop-in, Bassani catted X-pipe, Magnaflow cat-back system.
I noticed the car was hesitating and bogging under load, then about 60 miles later, the SES light came on.
I started by pulling the codes P0304 and P0316. I then read a few threads and decided to join the forum, so thanks for having me.
I checked the spark plug and it looks fine as it should, considering I replaced it about 15,000 miles ago. The coil itself also looked fine.
I swapped the coils from cylinder 4 and cylinder 1 and cleared the code. I then started the car and it seemed wayyyyyy better right off the bat. No bogging, rough idle, or hesitation as I pulled away for the test drive.
I let it get about half way to operating temp and floored it in 1st. There was a pretty big hesitation, then a loud backfire, then the car rocketed forward with no hesitation and a nice smooth rev all the way to 6,500 rpm. I shifted to 2nd and floored it again but then there was a slight bit of hesitation through the powerband so I backed off. I drove until the engine reached operating temp then floored it from 1st through 3rd. The car is honestly running wayyyyy better than it was before I switched the coils, but still not perfect. There's still some slight hesitation and a bit of power loss.
Now I'm just waiting to see if when the light comes back on it will throw a "P0301" instead of "P0304".
Does anybody have any other suggestions to troubleshoot this? What's peculiar to me is this: Why would switching two coils to opposite locations make such an improvement? If the coil is bad, I'd imagine that the problem would persist just the same. Only the cylinder of the misfire would change.
TXMach is offline
Old 12-08-2013, 10:58 AM
tadpole1969
tadpole1969's Avatar
sounds like you may have had a bad connection if the problem went away dureing the swap look your cop connecters over well for bare spots on wireing and connecter its self also check to see if there might be water down in the sparkplug hole or debris
tadpole1969 is offline
Old 12-08-2013, 07:24 PM
TXMach
TXMach's Avatar
Yeah, that could be it. Unfortunately the problem didn't completely go away. It's better, but there's still some hesitation and power loss.
TXMach is offline
Old 12-09-2013, 03:59 PM
tadpole1969
if your still haveing the issue then i would go to autoparts and buy a ignition coil and install it on cly 4 if it solves the issue then keep the coil if it doesnt return it it is very possible it just before going bad might not be bad idea to get a sparkplug also that way you can rule it out as the cause for sure
Omgitsa88Stang
10-05-2015 07:33 AM
Matt's 95 Stang
10-05-2015 07:16 AM
jruddell
09-24-2015 03:22 AM
bconboy
09-21-2015 12:52 PM
classic69FB
08-12-2015 11:58 PM
Quick Reply: Misfire in cyl #4
