my 69 mustang coupe with an LS1 & 6 speed
Old 02-10-2012, 11:11 PM
badwolf4822
badwolf4822's Avatar
Default my 69 mustang coupe with an LS1 & 6 speed
This is my 1969 mustang coupe
originally 250 inline 6 with a 3 speed
Has a built, bored, & stroked 02 corvette ls1
driven through a new custom built t56
all ending up in a 9.5in posi rear end
has 13in drilled & slotted 4 piston wilwood brakes all around
a 14 point roll cage, and no interior besides carpet and seats
dash is just flat sheet metal with all the instruments
suspension is 2in lift coils front and rear leafs for an f100 so 2ft lift from stock
painless wiring chassis kit and separate painless ls1 kit
before the engine swop
still waiting on the headers
then it needs a new paint job and smaller wheels
badwolf4822 is offline
Old 02-11-2012, 12:27 AM
badwolf4822
here is the engine when it was being assembled
this is the 1st day I brought it home
brakes
20 gallon fuel cell
a little test fitting
Old 02-12-2012, 11:54 AM
lizzyfan
Underboss
lizzyfan's Avatar
Very cool!!!
lizzyfan is offline
Old 02-12-2012, 12:28 PM
Matermine
Matermine's Avatar
Looks great! Make sure to post final pictures also.
Matermine is offline
Old 02-12-2012, 02:10 PM
nj07
nj07's Avatar
Ls1 power nice!
nj07 is offline
Old 02-12-2012, 03:10 PM
Soldier GT
Soldier GT's Avatar
That's gonna be one bad ***** when you're done it!
Soldier GT is offline
Old 02-13-2012, 04:57 PM
badwolf4822
mounts I had to make to go from mustang to LS1
Old 02-15-2012, 04:14 PM
jer305
jer305's Avatar
Thumbs up
Nice build, I'm very interested to see the progress on this.
With those motor mounts how does the shifter hole line up? Do you have a picture of clearance of the oil pan from sway bar, cross member, and steering rack?
jer305 is offline
Old 02-15-2012, 04:55 PM
badwolf4822
had to use an 04 gto oil pan to make it front sump
after that it lined up perfectly
and for the clearance I wanted for the t56 I had to cut out the trans tunnel
so still making the new one from sheet metal
i'll post some pics of progress once the rain stops and i can get back to welding
Old 02-16-2012, 04:00 PM
jer305
jer305's Avatar
Looking forward to the pics and the details for the rest of this swap.
I have a standard 69 Cougar being rebuilt that just so happens to have a LS1 sitting next to it in the shop just waiting for the right time to drop it in.
How is the clearance for spark plug changes? Some older posts on the web say its tight fight (as in 1 or 2 inches of room) with the shock towers.
jer305 is offline
Quick Reply: my 69 mustang coupe with an LS1 & 6 speed
