My new build (2013 5.0)
Old 09-19-2014, 05:00 PM
  #121
Sleeper_GT
Sleeper_GT's Avatar
New wheels are here....Just waiting on tires and to finish the Airlift install.
Sleeper_GT is offline
Old 09-20-2014, 07:28 PM
  #122
Sleeper_GT
Sleeper_GT's Avatar
Did some work on the airlift install. Plan to run the lines tomorrow.
Old 09-21-2014, 08:16 AM
  #123
RCrumb
RCrumb's Avatar
I just carry a spare in my truck, way less weight than a tech.... :-)
Nice build thus far.
RCrumb is offline
Old 09-21-2014, 01:09 PM
  #124
Sleeper_GT
Sleeper_GT's Avatar
Oh man....That's hilarious
Old 09-21-2014, 06:40 PM
  #125
Sleeper_GT
Sleeper_GT's Avatar
Still going.......Not finished, but all line and wiring are done and I have the tank and compressor layout finished. Now I just need to get that installed and everything hooked to the tank and manifold.
Old 09-26-2014, 01:28 PM
  #126
Sleeper_GT
Sleeper_GT's Avatar
Blowfish Racing Shift Bracket installed. I'm using it in conjunction with my MGW.
Parts used for the install with an MGW shifter.
With the MGW you will reuse the two post bracket. Attach the two post bracket to the Blowfish adapter bracket.
The MGW two post bracket will be re-installed, but you would install it upside down so the Blowfish adapter bracket is facing down.
The instruction now call for you to install the lower bracket. If you have an X-Pipe I suggest that you install the upper bracket first according to the instructions and slide it towards the rear of the vehicle out of the way then install the lower bracket. I had to remove the lower bracket and do this. The "X" is right in the way of being able to rotate the upper bracket around the Drive Shaft.
Next slide the upper bracket in position and connect the upper bracket to the blowfish adapter bracket. Just get them started and move on to connecting the upper and lower bracket together. (But do not tighten, just get them started.) Once that is done go back and tighten the upper bracket and adapter bracket according to the instructions.
Next tighten the upper and lower bracket together according to the instructions.
Old 10-05-2014, 10:27 PM
  #127
Sleeper_GT
Sleeper_GT's Avatar
All I need now are my tires then I can mount up the wheels, drop the car and calibrate the system........Air Lift install, complete....
Old 10-06-2014, 06:20 AM
  #128
Jeffk
Jeffk's Avatar
Location: Thomasville, NC Where we beat headers into submission!!
Looks killer JJ!
Jeffk is offline
Old 10-07-2014, 09:40 PM
  #129
Sleeper_GT
Sleeper_GT's Avatar
Thanks.....I really want my tires to come in. Really want to see how the air lift rides and try out the blowfish bracket.
Old 10-10-2014, 03:36 PM
  #130
Sleeper_GT
Sleeper_GT's Avatar
It's finished.....
Wheels on.....
The tank...
Ride height...
Park height....
Quick Reply: My new build (2013 5.0)
