Motor Swap Section Tech and Follow-My-Build Threads for members looking to put a different engine in their Mustang
Ls1 swap in 99 v6 mustang
Old 12-10-2012, 03:56 PM
35thMustang99
35thMustang99's Avatar
Default Ls1 swap in 99 v6 mustang
Has anyone done it? Do you run into any problems? any tips before hand? and also will the ls1 turbo kit work in the mustang or u gotta make custom pipes.Motor and trans run about 3k on eBay. Just want some knowledge about it before we do the swap.
35thMustang99 is offline
Old 12-11-2012, 05:40 PM
clowe1965
clowe1965's Avatar
If they can do it in a miata you can do it in a mustang. Bit sacrilegious but as they say ford tough chevy stuff. Given all the piping you have to install for a turbocharger you will probably be best off piecing together your own kit. Find an ls1 car and take measurements around the exhaust manifolds, focusing on clearance between the framerails and steering system. If those measurements are similar then you can probably use the ls1 turbo headers. It may be necessary to raise or lower the motor so build that into your motor mount setup. Best way would be to have the turbo manifolds mounted and position the motor with them in place. Mount the intercooler, then plumb the connections with a universal turbo kit. If you need something special then take it to a shop to have the fitment done locally.
clowe1965 is offline
Old 12-12-2012, 09:53 AM
35thMustang99
Thanks for the info
Old 12-12-2012, 10:44 AM
uberstang1
Chupacabra
uberstang1's Avatar
Thousands have put ls motors in mustangs, nothing new. You can buy kits and k frames to drop the motors in.
uberstang1 is offline
Old 12-12-2012, 10:16 PM
jthorn9
The Godfather
jthorn9's Avatar
Here is one part of the suspension kit needed.
http://www.uprproducts.com/mustang-p...-urethane.html
You will then need
LSX Motor
GM Transmission
Wiring Harness
GM Cooling System
That's just to scratch the surface.
As stated it's been done quite a bit. Just google it, there are a few sites dedicated to this info.
jthorn9 is offline
Old 12-20-2012, 05:33 PM
LilRoush
LilRoush's Avatar
Don't forget the rear end since you are starting with the V6. You'll want to upgrade to a nice 8.8 to get rid of the 7.5" open diff the car starts with.
LilRoush is offline
piotrek53
10-13-2015 06:54 PM
marc954
09-29-2015 03:05 PM
marc954
09-25-2015 06:48 AM
Brett Ludlow
09-23-2015 06:59 AM
jaiidutch
09-14-2015 10:29 AM
Quick Reply: Ls1 swap in 99 v6 mustang
