Check Engine Light - Cam Sensor
Looking for techincal feedback. I have a 2002 GT. Check engine light came on 3 weeks ago. Three different repair shops (including the Ford Dealer) have run a diagnostic..each one shows the only thing bad is the "cam sensor." I have had it replace with Ford factory parts, but the light still comes back on. The mechanics can not figure it out. Anyone had this issue?? The car has a soft backfire (one pop...then care dies) about 50% of the time when it is first started. Once car starts, it runs smooth at idle and all the way to 6000 RPMs.
I put a new battery in the car because I was told a weak battery could cause a small backfire and check engine light to come on. This was not my problem. Any feedback is appreciated.
RE: Check Engine Light - Cam Sensor
You need to post this in the correct technical forum. If you don't know which one, ask a moderator for help. You'll have better luck getting an answer. I think you should be in the 4.6 tech forum.
