Having problems after putting headers on my 88 5.0
Old 05-13-2014, 01:32 AM
Retroz88
Retroz88's Avatar
Default Having problems after putting headers on my 88 5.0
Ok, so I changed my headers to some hedman longtubes and put an x pipe with flowmasters. I had to drill holes for the o2 sensors in the headers. I have only the front o2 sensors hooked up. My problem is, I cant get it to idle. what do you think it could be?
Retroz88 is offline
Old 05-13-2014, 06:51 AM
88 orangepeel notch
88 orangepeel notch's Avatar
Welcome, but you may get more advice if you post this question in the Fox/SN tech section. Otherwise, pull codes to see what your ECM is storing. Is your CEL on ? If it was idling fine before the swap, disconnect battery, reconnect after a couple minutes and do a base idle reset. Use the search feature on this forum to find step by step instructions. Good luck and keep us updated.
88 orangepeel notch is offline
Cannibal_carnies
03-02-2023 06:17 PM
djbigskrilla
09-20-2022 01:04 AM
prophotog
08-26-2015 11:55 AM
kevans79@yahoo.com
08-18-2015 09:01 PM
KEM Motorworks
08-14-2015 10:13 PM
Quick Reply: Having problems after putting headers on my 88 5.0
