as some Oil company are finally offering a few extended drain
lubricants, the 3,000-mile oil drain mindset still dominates
the industry. Valvoline, for example, has reinforced
that recently with its introduction of its Valvoline
Engine Guarantee program. Essentially, this program
guarantees an engine for up to 300,000 miles if Valvoline
motor oil is used. Impressive on the surface, but there
is a little more to it than that. Valvoline attached some
qualifiers. First and foremost, the Valvoline motor oil,
along with the oil filter, must be changed every 3,000
miles throughout the duration of the program. Qualified
vehicles must be registered prior to reaching 75,000
miles, Valvoline motor oil must be used for at least 18
months prior to registration and no vehicles older than
1990 models qualify. Diesel powered vehicles don’t
qualify for the program, nor do vehicles used for racing,
vehicles over 10,000 pounds or vehicles with modifi ed
engines. That’s understandable.
Valvoline has further qualified the program contingent
on the type of oil used. To gain the 300,000-mile
coverage consumers must use one of Valvoline’s full
synthetic products. Using a Valvoline synthetic blend
carries the coverage to 225,000 miles and a Valvoline
conventional oil carries it to 150,000 miles.
To be sure, Valvoline has done its homework. Very
few, if any, claims will ultimately be paid. On the low
end, 150,000 miles is virtually no stretch for today’s
engines. On the high end, very few motorists drive the
same vehicle for 300,000 miles, and the guarantee is
not transferable. There is no question that the profi ts
are there for Valvoline. Assuming a motorist drives
15,000 miles per year it would take 20 years, driving the
same vehicle, to reach 300,000 miles. That’s 20 years at
five oil changes per year. That’s a lot of Valvoline motor
oil sold.
Clearly, the push behind the Valvoline program is
profit, and a person can’t fault Valvoline for that. We
are all in this business to make money. What you can
fault Valvoline for, and all others who continue to support
3,000-mile oil change intervals, is their irresponsibility
in regard to consumers and the environment.
To be sure, way too much money is being wasted on
unnecessary oil changes, and way too much used oil is
being generated.
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
Vehicle: 02 Ford Mustang GT and 03 Crown Victoria PI
Thats marketing for you.
__________________
2003 Grey Crown Victoria Police Interceptor the DD stock
2002 Silver Mustang Gt not stock
JLT Cold air intake
Accufab 75mm Throttle Body & Plenum
Mac longtube headers
Dr.Gas o/r x
SLP Loudmouth 1
3.73 gears
Steeda tri ax short shifter
H&R sport springs
Tokico HP Shocks & Shruts
18x9/18x10 Black chrome bullitt rims
SCT Xcal 2 tuner done by JMS Chip and perf. http://Centraltexasstangs.com
yeah i'm not suprised, nothing is what it seems, the last thing i heard about something good, i laughed. EVERYTHING is a scam or to good to be true these days.. i don't even waste the time. the money i spend on the oil i could have a built motor put it in for another hard strong 100k.
__________________
1996 SVT Cobra
*FRPP4.10's
*cold air intake
*superchips tuner
*FRPPaluminum driveshaft
*straight pipes no cats flowmasters
*Black cobra floor mats
*chrome fuel door
*Accufab1600cfm throttle body
*Chrome appearance hood pins
*Steeda Tri- axShort throw shifter
Nothing surprising there, and theyre not doing anything wrong. I was going to do this with my Dodge Pickup, but I missed the max mileage limit
__________________
" You, me, or nobody is gonna hit as hard as life. But it ain't how hard you hit; it's about how hard you can get hit, and keep moving forward. How much you can take, and keep moving forward." - Rocky Balboa
Agreed. VERY irresponsible but whatever. Don't buy valvoline. I wouldn't.
I'm at 40k miles and have swapped my oil filter with Amsoil sig series 0w-30 and filter ~5 times @ $85 per change. The first two changes were @3-5k and the last three around 10k. $425...my car runs like new and performs like new. When I removed the valve covers to swap my cam phaser bolts it looked like new and the cams had marginal if not zero wear.
By 100k I'll have invested $1k in maintenance but I'll probably still have another 50-100k in engine life. It's worth it to me.
__________________
2007 Alloy GT Coupe/MGW shifter/C&L Racer CAI/JBA LT's/JBA catted H/Pypes M-80 race mufflers/Steeda HD engine mounts/LFP 17# driveshaft/FRPP 4.10s/Truetrac/Steeda Ultralite 18x9.5's with 275/40 and 285/40 Nitto NT555/Autometer DPSS shift light and gauges. Suspension: Steeda Comp Springs/GT500 Front CA's with Steeda X5 balljoints/Steeda bumpsteer kit/Tokico D-Specs/BMR adj upper & lower LCAs+relocation brackets/Hotchkis 3/4way adj swaybars/UMI Performance panhard.
I only change my oil in the stang in the sig once a yr!!!!!!! My DD gets 2-3 times a yr.
I am not surprised at Valvoline but feel (like others have stated) that it is very irresponsible for any business or car owner to push something that will hurt the amt of fossil fuel we have 50 yrs from now esp when it is not necessary to change oil at 3000 miles/3months
__________________
2006 Mustang GT with Cervinis Kit
Whipple Crew member
H.O. S/C 465 RWHP and 440RWTQ
So your saying, you guys don't change oil at 3000.. Exuse me for being a noob and most likely an ignorant one at that.. But I thought 3000/ every three months, was standard practice. Long as i don't use water to clean out my crank case I should be fine..
I wouldn't use anything but Royal Purple(possibly giving Amsoil a Shot one day) especially not Valvoline.
No oil is guaranteed for anything.
I went 7200 Miles and 7 months on 6 Quarts of Royal Purple. I got every drop of 6 Quarts back, and the oil came out a medium Brown. The Purple dye is gone after about 100 miles, so don't let that fool ya.
Anyhow, Don't go with Valvoline. Get Amsoil, Mobile 1, Royal Purple, Shaeffer Oil, etc.
__________________
2003 10th Anni Torch Red Cobra 462 RWHP 486 RWTQ SAE
Fluidyne Heat Exchanger
H&R Springs
K&N FIPK
Mac O/R Prochamber and Borla Stinger C/B
BF 2.76 Pulley
LDC Chicago HCM
Many more mods
