Oil change: synth vs. dino
#21
According to the "Pre-sale" service paper work they gave me when I bought the car in Sept. it shows oil and filter 10w-30 at $3.69 a qt which tells me that it was dino.
It doesn't smoke at every start up. If I start it up and move it out of the garage then start it up even an hour later it will smoke. It's still under warranty so if it gets worse I will take it to the Ford dealership.. that should be interest.
#23
Just replace the pcv valve first its under 5$ and go from there, if a car puffs a little oil on start up or on gas from extended idle its usually a hardened/worn valve seal, and beleive me unless its BAD the dealership isn't gonna tear into the head to replace them they will simple rule it as normal oil consumption.
#24
I have a steep driveway; If I pull my car out of the garage to wash it then start it up a short time later it will smoke like the rings are shot!! White smoke everywhere. Other than that it doesn't burn a drop or smoke at all.
I had a 2008 (and now a 2010) and they BOTH did it from day one.
I've read about it on a couple of different forums.
