Oil and Oil Related Topics A place to post your oil related questions and comments
When changing oil because of time rather than mileage..
Old 03-17-2012, 12:23 PM
99GTvert
is my username.
99GTvert's Avatar
Default When changing oil because of time rather than mileage..
I run motorcraft synthetic blend in the 99. It has not been even close to 5k miles since the last oil change, however the last time it was done was late last year, and I think its time to change it now.
I have some fresh oil & a new filter to change it today but I was wondering about a "rule of thumb": Without heavy stop and go conditions, typical oil life for a synthetic blend might be good beyond 5k miles, but what about in terms of time? On a vehicle not driven that often (meaning not accumulating many miles), would that oil be OK for 5 to 6 months between changes? Or more?
Also, synthetics have longer intervals but by how much?
99GTvert is offline
Old 03-17-2012, 03:50 PM
Snakebite64
Snakebite64's Avatar
I change mine every spring and it (the oil) has approximately 600-800 miles worth of wear. I have been doing this for 25 years and have not had any problems. Oh Mobil 1 or RP
Snakebite64 is offline
Old 03-18-2012, 12:30 PM
6-Speed
6-Speed's Avatar
My Mustang doesn't rack up many miles so I change the oil (synthetic) once a year ... in the spring. When I changed the oil last week, it had only 880 miles on it.
6-Speed is offline
Old 03-18-2012, 12:31 PM
SD 197
SD 197's Avatar
Recommended yearly change regardless of miles.
SD 197 is offline
Old 03-18-2012, 01:36 PM
Unleashedbeast
Unleashedbeast's Avatar
Syn blends and conventional oils - 6 month intervals, or 7,500 miles
Refined petroleum synthetics (Mobil 1, Castrol, etc) - 12 months or 10,000 miles
True synthetics (Red Line, Royal Purple) - 12 months or 10,000 -12,000 miles
True synthetics (Amsoil SS, Mobil EP) - 12 months or 15,000 miles *I have done 18 months before on a low mileage interval with no ill effects on the UOA*
Unleashedbeast is offline
Old 03-30-2012, 06:31 PM
mustangman02232
mustangman02232's Avatar
say no to RP 04 cobra with 12k and oil changed ever 2k
gassers get valvoline blend 530 or 1030 once a year or 5k
diesels get 540 Shell rotella syn
allways use factory filters
mustangman02232 is offline
Old 04-01-2012, 10:11 PM
Unleashedbeast
Have any better pictures of your oil pan? That looks like moisture contamination in the oil.
Old 04-02-2012, 10:17 PM
94Blk5.0
94Blk5.0's Avatar
^ That, and who knows if it was running pig rich...
94Blk5.0 is offline
Old 04-26-2012, 11:06 AM
Unleashedbeast
Possible fuel dilution if true.
Old 09-05-2012, 12:30 PM
04goat
04goat's Avatar
i run 20-50 rp in my modded ls1. being cammed i wanted the extra lubricity it has.it is full synthetic. and it see's 7000rpm each time it goes out.
04goat is offline
Quick Reply: When changing oil because of time rather than mileage..
