supercharger
#21
RE: supercharger
stock injectors???.. that'll do it. Those injectors can't give your engine the fuel it needs to keep up with the forced induction. You have about 26lb injectors now. You need atleast 30lb.s
Do you have a chip as well?
#23
RE: supercharger
yea i have the hypertech power programmer. we will try to bump up the timing tommorow, to see if that is it. man this has been freaking nightmare. it is like 4200 bucks down the drain. what size injectors should i get and where is the best to get them. can i install myself. thanks for all the help people!
[IMG]local://upfiles/6083/7308CC4770CD4D8D949B77A3D2C63682.jpg[/IMG]
[IMG]local://upfiles/6083/77D2CC3F8DDA4CC1BD3252097EBD9D3B.jpg[/IMG]
#24
RE: supercharger
Do NOT touch the timing....
Absolutely DO NOT touch the timing. If you are running lean as it is (you definitely are) and you bump up the timing, totally kiss your motor goodbye.
Go with 30lb+ injectors and stop driving your car until you get them. I cannot BELIEVE that shop installed a blower on stock injectors...
Call whoever you got your SC from and find out whats best.
#25
RE: supercharger
Plus... a hypertech can not tune for injectors... you need a Diablo Preditor programmer or custom burned chip. Timing isn't your problem.... you should have found this site before you put the blower on...
#28
RE: supercharger
What is the make of your SC?
You can't use stock injectors with a blower! You are running far too lean. You have to use 91 or higher all the time.
I wouldn't drive it until you find out what size injectors you need.
#29
RE: supercharger
hey dan i am running the vortech v2 sq s trim. when i spoke to vortech WAY before the purchase they said for this kit bigger injectors are not recommended. but do you think i do? i always run the good stuff (gas).
