nitrous jet placement
RE: nitrous jet placement
First of all, as stated above, make sure it's between your TB and your MAF. Unless it's a dry kit, in which case you want to have it before your MAF so that it can be properly metered.
Now, as far as installing it and gtting it to stay, that's simple.
First, just drill a hole where you want it to go. Next, get a fogger nozzle mount and place that in the hole. Usually, you push one end through and screw it down on the other end. Finally you just screw the fogger into teh mount (making sure that the nozzle opening faces towards the TB in the direction of airflow.)
Here's a pic of what a nozzle looks like when screwed into a mount.
The nitrous lets themselves would sit inside of the top of the nozzle. Then you just screw the fuel line and the nitrous line over the jets.
And in case you're wondering... fuel jets and nitrous jets are the same. Only thing that matters is the size.
ORIGINAL: fiad06
I have the stock intake on my car and i was wonderinf how the fogger goes in and stays in the intake....I bought the kit used?
[IMG]local://upfiles/20114/A4CA7193CB1F4E7694C729FF7B10E141.jpg[/IMG]
yea i already got the fogger where the both lines meet, but where do i buy the other piece that holds it in the intake......
To the poster...on an 03 gt it should look like this......... https://mustangforums.com/upfiles/47...42F3071A9C.jpg
ORIGINAL: bryanec
You beat me to it sam. Make sure the lock nut on the adapter is on the outside of the tube.
[align=left][/align]
ORIGINAL: fiad06
11-10-2015 11:39 AM
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
