Supercharger or turbo?
#23
RE: Supercharger or turbo?
ORIGINAL: OneFastEclipse
The hot side of the turbo has little to do with a boost spike. On a cooler day, a turbo can pull in more air per revolution as well as spin up even faster causing a change in the power curve. Any change in when your car is making power plays hell on your tune. The wastegate problem your thinking of would be more do to boost creep, which I said in my original post is usually due to other things, though it can be caused by changes in weather as well.
#24
ORIGINAL: FoxGT
I know what causes it. Once you reach boost threshold, boost shoots up incredibly fast & can sometimes go past what your boost is set at, then settle back down. I know that cold days make the air more dense causing it to happen faster. What i'm saying is your wastegate should be opening to vent off the exhaust gasses to keep it from happening. Either your vac line going to the wastegate is too long or your boost controller is junk. spikes aren't a problem when properly set up. I know it's a problem with some stock turbo cars, but it can be fixed.
#25
You clearly don't seem to know what causes it. A spike happens before the wastegate even has the chance of opening. Thus the reason the boost settles back down after it does open. A boost controller isn't even necessary on a turbo setup with a proper wastegate. Spikes can and will happen regardless, some setups more drastic then others. Boost creep on the other hand usually has to do with a malfunctioning or inadequate wastegate.
I can probably find about 30 sources saying it has everything to do with opening the wastegate, either there being a buildup causing the wastegate to resist opening, too long of a signal line, boost control solenoids (which opens the valve to let pressure to the wastegate actuator) sticking. The only reason I know about it is because I had a spiking problem with a kit i built about 4 years ago, so talked to quite a few companies about the causes of it & what could be done to fix it. I personally don't like going to just one company about a problem in case they dont know & pull an answer out of their *** so I'll ask multiple companies before I try what they suggest. Considering I've had a big problem with it & after gathering quite a bit of information fixed it I know from experience that I've fixed it on at least one of my kits & haven't had a problem with it since probably just from that experience alone.
consider how many cfm your engines flowing & how fast the air is going to move to shut the gate (unless you have a 1lb gate which no company in their right mind uses a super heavy one). I don't know of one properly set up turbo system that has a problem with spiking.
I know a boost controller isn't required, but it can be a cause of spiking & a good boost controller can help eliminate the problem on a stock setup or a poorly built aftermarket one.
creep and spike both have alot to do with the wastegate. but creep is caused by a completely different thing than spikes. If it would help in the future I could even email a couple of major companies & we could wait a few days to see what they say about it.
#26
ok so Eclipse...you went supercharger and how is it treating you? like are u getting what u need out of it? and what kind do you have?
And Fox...do you have a supercharger or a turbo?
#28
Well, I can't say that I own a company (though it would be nice!) but I do have lots of experience when it comes to turbochargers. Basically, if you are having a issue with boost spike right from the get go after you install a kit and can not get it to go away, then yeah I could see what your saying may help by making the wastegate actuator more sensitive. That's not the issue I'm talking about though. What I am referring to is when you have a turbo setup on a car, it's been tuned and perfected at one temperature, we'll say 80 degree summer weather, and then say fall weather comes around and now you have 50-60 degree temps. With that kind of change in climate, the change in air flow is drastically increased and it can cause boost spike and in some instances, boost creep as well. I guarantee anyone that has ever owned a modified turbo car has seen boost spike and/or creep at least one time in their hobby, some more severe then others. It's just something that comes with setup.
@Snowboard49dude Should you not buy a turbo system simply because of this? Absolutely not! Turbos are a awesome way to make huge power numbers. Just remember, "With great power comes great responsibility" (I love that quote ). You have to be willing and prepared to make changes on your tune and setup when needed with your turbo system. Either that or make everything real fat and conservative to keep it safe.
I absolutely love my supercharger setup. It is a Vortech S-trim and I am running methanol injection along with it. It is a totally different feel then a turbo and produces plenty of power. Hopefully I'll get it to the dyno within the next month and see exactly what I can get out of it. Shooting for between 450-500rwhp. The weather finally started to get nice around hear so after I finish moving into my new house, I can go ahead and finish everything I been meaning to finish on the car for the past 6 months.
#29
Who are you talking about that had this problem? Someone on the forum, if so I could talk to them & see what's up with their setup. I don't see it happening unless something was done wrong. I dont get why that person would tune the car for a certain temp either rather than include it unless they overlooked the feature or got a bad tune.
#30
ORIGINAL: FoxGT
I guess I just dont see it. I don't understand what the tune has to do with the manifold pressure opening & closing a valve. While tuning has to do with air/fuel ratios & ignition & boost has to do with the pressure or vacuum in the intake altering the condition of a valve. I don't see how a tune could slow down the effect of the wastegate even with a horrible tune or a tune perfected for a certain temp (which I don't understand why you would tune it for a certain temp when you could include an intake air temp sensor to alter the tune under those conditions) They're two systems that have nothing to do with eachother, one being pressure controlled, one being electronically controlled (in most cases). Even if you went with a solenoid to control boost to have a lower boost threshold.
