cam suggestions
cam suggestions
Anyone have a suggestion on a Camshaft for a worked mustang thats not track but is fairly aggressive but not over the top for a daily driver? need suggestions. So far i only seen what americanmuscle.com offers. thanks guys
The Ford Racing cams are respectable cams. However they are slightly outdated and are single pattern cams. Check out the TrickFlow cams. The Stg. 1 is rather mild, sounds good, and has a good power range(2200-6000 I believe). They are also a dual pattern cam. You can get them at summit for $160. If you are really serious about getting every last horsepower out of your combo check out a custom cam.
I'm running an x303 in my daily driver. I'd have to agree with nogo, I would go with a dual pattern cam aswell. Don't get me wrong, i'm way more than happy with my x303 & this engine was a cheaply built engine. I got down to 12's on the stock heads/street tires/pump gas. If I was going all out I would have went with a different cam. I wanted decent power/low cost.
Call Comp Cams. Tell them what mods you have on your car and tell them what your future plans are with your car and they will tell you exactly what you need. I spent a little over $900.00 and I am very satisfied.
folivier
Tennessee Regional Chapter
10-02-2015 05:32 AM
