Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
100 shot feels like it looses power at 5k why?
Old 09-24-2008, 08:00 PM
tempoffroad
tempoffroad's Avatar
getting all my gauges hooked up this weekend nitrous pressure and fuel pressure both electric that will be on my a piller and plan on getting a tune soon as i can. Thanks for everyones help.
tempoffroad is offline
Old 09-24-2008, 11:36 PM
302army187
302army187's Avatar
remember, when you up your bottle pressure high, it makes the shot hit harder, so if your on the brink of being lean, you might not want a ton of pressure.
dyno for sure to see whats up, then maybe a tune
302army187 is offline
Old 09-26-2008, 07:32 PM
01GT4.6
01GT4.6's Avatar
he told me that his plugs are gaped at .044., he could be getting spark blowout. I think he should re-gap to .035" and try it again at 950+ psi. If it still does it I'd get it on the dyno to see what's really happening.
01GT4.6 is offline
Old 09-26-2008, 10:42 PM
lilc1511
lilc1511's Avatar
wideband o2 sensor
lilc1511 is offline
Old 09-27-2008, 09:53 AM
Obsol3te
Obsol3te's Avatar
Well, obviously not getting the required fuel there.
Stop running the kit until you can get some sort of A/F reading on it, or risk doing some serious damage to your engine.
Obsol3te is offline
Old 09-27-2008, 10:58 AM
tempoffroad
plugs regaped at 34-35 and will order a wideband this week to see what is going on. where should it read with and with-out the spray?
Old 09-27-2008, 11:23 AM
Obsol3te
Obsol3te's Avatar
Optimal Air/Fuel on juice is around 12:1-11.5:1
Off the juice you'd want around 13:1
But I can guarantee it's nowhere near that right now when you're spraying.
Obsol3te is offline
Old 09-27-2008, 02:47 PM
tempoffroad
not going to spray till i get on the dyno witch i have set up for wed at 5. its 450 for the dyno and to install some type of switch that i can go from na to spray tune with a switch. They are suppost to be the best tunner around, i will post up # when i get it back
Old 09-28-2008, 04:53 AM
Obsol3te
Obsol3te's Avatar
cool man, good luck!
Obsol3te is offline
Old 09-28-2008, 07:42 AM
302army187
302army187's Avatar
glad to hear your getting it worked out.
one of the goodthings about nitrous is you can take it away from the car for a week or two, and get use to that n/a feel again, then when you use the nitrous again it feels like a monster
Quick Reply: 100 shot feels like it looses power at 5k why?
